2003 taurus drivers window will not go up
You either need a motor or motor and window regulator assembly.
SECTION 501-05: Interior Trim and Ornamentation
2002 Taurus/Sable Workshop Manual
REMOVAL AND INSTALLATION
Front Door Trim Panel
Removal and Installation
Remove the front door trim panel.
SECTION 501-11: Glass, Frames and Mechanisms
Front Door Window Regulator And Motor
Special Tool(s)
Heavy Duty Riveter
501-D011 (D80L-23200-A) or equivalent
Door Window Regulator Motor
SOURCE: my ford taurus 2003 windows will not work at all
First Checkup the power window fuses. If they are good, check the wiring lines whether the power supply is available for all the windows. If you have problem in power supply approach to nearest garage / dealer
SOURCE: 2003 ford taurus windows went down but wont go up
sounds like the window motor/ regulator.....need to take the door panel off to see what's going on.
SOURCE: 2003 ford taurus. electric windows not working
Do the windows not work only from drivers door switch, or the doors themselves?
If from drivers side switch, then you need to replace the window switch or maybe some of the wires came loose. If the windows arent working individually, you have short somewhere, or all your motors went out, which I doubt.
SOURCE: 2003 FORD TAURUS - 2 OF 4 POWER WINDOWS WON'T WORK
Your car battery may be at fault. My brother's 10 year old Mercury
had problems with air conditioning in auto mode, headlights were
dim,and door locks were mostly inop.
Problems cleared up after new battery was installed.
E Maslak 130 Hurd st Bradford Ont
