TV Switches itself back to standby mode continuously
When I switch the TV On from standby mode via the remote, the TV will switch itself off - or rather back to standby mode. This happens continuously until I have switched it back on - on average 20 times. This number varies from between 1 to 30. It's as though the TV needs to warm up before deciding to stay on. Any help is much appreciated.
  • Anonymous Nov 11, 2007
    I turned the TV off and tried to turn it back on. Now it is is stand by mode and it will not come on. Not impressed with quality compared to other tv's
    I have had for very long with no problems.
  • Anonymous Mar 29, 2014
    Cannot open though the redlid light is on...howwto fixthis pls.help
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
If your remote is ok then this is due to power supply failure in your tv. either it is loose in oscillator ckt in switching section or it has failed. if not tech person call tech to fix it. not a major problem.
Posted on Oct 07, 2007
Sky remote code for model UE40J5100AK
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Press "TV" again then enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press TV then the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at:Skyplease remember to use your back button and come back to us.
www.electro-medical.blogspot.com
Samsung brand code 0060
3 digit code for Samsung
065, 584, 037, 245, 476, 398, 516, 292, 318,037
Oct 13, 2015 | Samsung Televison & Video
Tv wont switch on with remote or the button on top of the tv. The standby button is on (red). sometimes it comes on by itself and switches off by itself (onto standby mode) not sure of the model as its a...
It could be one of a couple of problems really, the first one may be that your analogue signal is being switched over to digital which is happening across the UK at the moment, buying a digital receiver would resolve this straight away. It could be a problem with the ariel connection to the TV, check that its all pushed in properly at the back of the TV. Failing this then its a problem with the TV set, the fact that the set produces a picture on other sources (dvd) implies that if it is a fault with the TV its with the ariel connection.
Mar 31, 2011 | Sanyo Televison & Video
I don't have my booklet that came with my universal philips remote. i don't know the codes that connect it to the tv.
Turn on your TV. With the remote, press learn.
Press up then standby continuously until the TV switches off and at that point store the setting on the remote commander as that is the code that it has found itself.
If in doubt, google your remote control number and follow their instructions.
Hope that helps.
Nov 14, 2010 | Philips Televison & Video
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
We have a large tube pansonic wide screen tv. it sometimes would stay in standby mode and would not turn on when using the remote or channel switches on the tv.. this is getting worse to the point where...
This fault can be caused by low secondary supply voltages often caused by the value of capacitors becoming low and requiring replacements but you will have to have a technician.
SUPER8
Dec 01, 2008 | Panasonic Televison & Video
BUSH ID - HD TV
Try Checking your remote and make sure it did not short out by taking out the batteries and see if it continues turning on and off. if so then i would recommend replacing the remote. if this does not work try putting tape over the ir receiver and see if it continues, this will check for interference.
Nov 05, 2008 | Bush 5693D 24" TV
Model RE44SZ21D when I switch TV on it maks a whinning sound like a hard drive not reading properly and switches back into standby. Sometimes it will start, (normally if not tried for sometime) stays on...
hello john.
this is a late suggestion,but if you still have the set & the proplem
in existence.
then i suggest you check with the lamp---situated on the right hand
side ,two screws to undo--once in further two screws--pull back the
casing clean with a dry cotton cloth & with that clean the cooling
fan just adjasent to the case.+ remember to leave the tv on standby mode for 3 minutes before you completely switch it off ,as this helps to cool down the lamp the fan at rear still propels while the tv is in standby mode.--------ASH
Aug 14, 2008 | Televison & Video
Problem with SHARP AQUOS LCD TV - LC32GA6E: It switches on by itself!
Is the remote in the room and pointed at the tv when this happens? If it is try fresh batteries in the remote.
Jun 12, 2008 | Sharp Televison & Video
SHARP 29" TV switching off to Standby
have you tried changing the batteries just to elimate this problem
change them
sometimes if the batteries are low in electronic devies, they send a wek signal to its receiver (your tv),
your tv gets confused and then switches itself to standby
if you have changed the batteries and this problem still persists
it can only then be th PSU or power supply unit, take it to your local tv repair shop of mastercare somewhere like that, its going to be cheaper to get it repaired than replacing the whole tv
PSU'S generally 20 to 50 pounds depending on model
don't deo it yourself though unless you've got a capacitor discharger (or a nice 25KV will be on its way to your body)
hop this helps mate, let me know how you get on
Nov 10, 2007 | Televison & Video
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Televison & Video Logo
557 people viewed this question
Top Televison & Video Experts
