Question about Car Audio & Video
Astro in-car DVD player
We have just purchased a car with an Astro DVD player installed in it. It has no manual. When playing DVDs it works fine if the car is stationary however whilst moving it seems that the bumps on the road causes the player to freeze up and the DVD needs to be ejected to be able to work again. I have looked in the menu to see if I can enable an anti vibrate function but there seems to be no such thing. I hope there is a simple solution to this. Thanks
SOURCE: Sony DAV FC7 Stops Playing
Get a new machine
Posted on Jul 20, 2007
KaeZoo
  • 156 Answers
SOURCE: KVT-729 car DVD player
The steering remote control input is for a wired remote control, or a third-party interface that allows you to adapt vehicle steering wheel controls to operate your deck. Your problem is the parking sensor wire. This is supposed to be connected to your vehicle's parking brake switch. It detects when the brake is set, and will prevent a picture from showing when it's not set. The intent is to prevent you from watching movies while the vehicle is in motion. If you can get a good look at the parking brake mechanism, you should be able to see the brake switch. Usually there's a single wire coming from the switch, which is built onto the parking brake mechanism. Connect your parking sensor wire to the wire coming from this switch.
Posted on Jul 30, 2007
  • 279 Answers
SOURCE: DVD won't play
Netflix doesn't know what they're talking about. I looked it up - your DVD player doesn't have an autoplay feature. Can you try the DVD on another DVD player. Computers DVD drives generally read them differently - and decode them differently, than a regular DVD player. Also, if your DVD drive is a writable drive, it will have a stronger laser than your DVD player. I think it's likely the disk is damaged, slightly. If you cleaned your DVD's laser, it might be able to read it well enough to play - or it might not. I started having problems like this with a few of my own DVDs before my DVD player's laser went out. Basically it's a combination of laser quality and disc quality. If it remains just this one disk, I'd suggest leaving it alone. But if you start running into this problem on other disks as well, you'll probably want to have the laser replaced in your DVD player.
Posted on Aug 31, 2007
  • 286 Answers
SOURCE: movie skips and freezes during play
This is a common problem on CD and DVD players.
Altini is correct to a point. You can try taking the top case off, removing the DVD drive and taking the top off of the drive. Then use a q-tip on the laser lense. I use a little squirt of windex on the q-tip. Gently clean the lense even if it doesn't look dirty. Make sure you very gently work the lense up and down through it's travel. This will make sure no dust or dirt is interfering with the lense focusing.
Reassemble and try your movies again. This is a 50 50 proposition. If you still have the same problem, the mechanism has likely gone bad. Time for a new DVD player.
Posted on Feb 14, 2008
Eagleeyes
  • 199 Answers
SOURCE: Car DVD Player not working
hi sounds like its not reading your discs. try giving the dvd a clean and maybe try the DVD cleaning disc.
otherwise next stop repair agent.
Mark
www.blueice-electronics.co.uk
Posted on Feb 24, 2008
My Samsung smart tv & my dvd/bluray player recorder I bought at same time. Haven't had blurays til now & wont play at all. Rental ones did now I've bought my own & they don't play!Not tech minded.HELP
Each DVD player is assigned a code for the region in which it's sold. For example USA/Canada are Region 1 players. DVD players will refuse to play discs not coded for its specific region. In effect, this means that a DVD purchased in one country is normally unreadable on a DVD player bought in another region.
If your rental DVDs work in the player then there is nothing wrong with your DVD player. If you have purchased DVDs that do not work the problem is with the DVDs you have, not with the DVD player.
Jun 04, 2016 | Samsung Televison & Video
Netflix dvd not playable on SamsungDVD/VHS
Buy a cheap DVD player under $50 they play anthing.I have a $600 Toshiba Tivo DVR that won't play some DVD s.My $32 RCA plays anything.Good Luck.
Sep 07, 2009 | Televison & Video
After playing a cd in unit will no longer read DVDs
Had the same symptom. The unit would play CDs but not DVDs. The DVD laser was at fault. Purchased and replaced laser unit KHM-313AHC (ebay- $20) and it now works fine.
Jul 16, 2009 | Disney D7500PDD Portable DVD Player
WILL MY DVD PLAY AREA 1 AND AREAV4 DVD'S?
Hi camonk2004,
It's interesting that your DVD player was purchased in Russia but plays Region 1 DVDs. Region 1 is North America. Does your Player also play Russian DVDs (region 5)? If so, then it has probably been modified to play DVDs from multiple regions.
Check the back side of the DVD player - the rear panel should have a Region number on it. If the region number is 1, then try playing a Region 5 DVD. If it reads the DVD, then the modification that was done in Russia will probably allow it to read any DVD. IF the Region 5 DVD won't play (or if it is ejected automatically), then your player's region control os still intact, and it will only play DVDs from the same region as the one listed on the rear panel of the player (or DVDs marked "ALL").
I hope this helps - please let me know if I can be of any further assistance.
Kind Regards,
H2H
Dec 15, 2008 | Pioneer DV-U7 DVD Player
Symphonic Video/DVD player- dvds not able to be read so they don't play
possibly check the setup of the player. some dvd's will not work in most players. check the manual. if under warranty take back to store. or better yet buy another one like it and take the one that is bad back to the store with the new receipt.
Oct 24, 2008 | Emerson PD6810 CD Boombox
No picture, only sounds when playing DVD
The issue might be that you could be missing some codes to play the dvds.
First i want to uninstall all the codecs from the control panel - add/remove programs.
Then download the latest vesion of klite codec pack with the player.
The link is :
http://ftp.freenet.de/pub/filepilot/windows/multimedia/video/k-lite_codec_pack/klcodec390f.exe
Install this by selecting "lots of stuff" with the player.
Then play your DVD, it will work fine.
Good Luck.
Live, Love, Laugh.
May 08, 2008 | Haier PDVD10 Portable DVD Player
Premium Plan
I would love to help you. What is your problem with the DVD player?
Mar 28, 2008 | Zenith DVP615 Portable DVD Player
Windows media player
Windows XP does not come with the proper software to play DVDs. All major brands of pcs come with a piece of software called a DVD decoder. Once the DVD decoder is installed windows media player can play DVDs again. This software will be on your application recovery disks from your manufacturer. If you do not have these disks you can purchase them from the company who built your PC or you can purchase a DVD decoder software such as the ones found here. If you don't want to purchase one you can try a different program such as the VLC Media player to play your DVDs. VLC is a free download.
Nov 11, 2007 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
Car Audio & Video Logo
443 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
