Question about Indesit 24 in. IDL700 Built-In Dishwasher
Idl 705 Hi our indesit IDL 705 stops half way thought a wash with the red salt light on(despite salt being full), can reset it and get it away but not ideal any ideas? Thanks
    New Friend:
I have the same problem, what was the problem and how did you resolve it?
Posted on Sep 22, 2015
I have similar problem machine starts then stops while bleeping the second and third lights then flash nothing more happens have checked water intake which is ok no blockages any more ideas would help thanks
Posted on Mar 04, 2008
Ndesit IDL 535 DW, not cycling, water coming from under unt.
The washer is fitted with an anti flood device that detects water leaks and closes water inlet valve and puts washer in pump out mode. The anti flood device is a polystireen float with micro switch at the bottom floor of the washer. Dry the water and find the leak (pipe or pipe clamp) and this should then solve the error.
Jan 22, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit idl 705, tablet not dissolving and crockery still dirty, was working fine. Sprayer arm seems to not rotate freely
Clean EVERYTHING and ensure it's assembled correctly.
The sprayer arms have an unlocking ring and can be rinsed, the filters must be washed and rinsed and properly reassembled.
Even cleaning the door seals can help.
Test again, clean again (as more muck can be circulated).
Sep 27, 2009 | Indesit 24 in. IDL700 Built-In Dishwasher
IDL 700
A10 2 & 4 Heating element Open circuit heater
info from idl service manuall
Feb 29, 2008 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit idl 705
you may be in "flood mode". there may be a leak into the base. or your bottom base hoses may be blocked, best get someone in who is able to strip a d/w base out.
Feb 08, 2008 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit IDL 40 Slimline flashing lights
the problem you have got with the flashing lights is that its the rinse aid or in need of more salt, hope thats sorts it for you
Dec 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit idl 705
if the pump is not humming or is humming but not pumping i would replace it.
Nov 27, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I think I have the answer.
On Yahoo Answers Blue Rizla Girl put up the idea that the sensor is some form of hydrometer. (i.e. floats in salty water sinks if not salty enough)
Based on this thought I postulated that the sensor is some form of hydrometer float in a tube with perhaps an optical sensor.
If this is correct why is it not working?
Is it because the float is stuck at the bottom of the tube, perhaps by some food debris? If so how can we fix it?
This is what I did on my Hotpoint FWD60:-
I took the salt filler cap off. There was no salt in the reservoir as it has been a problem for months, and I was only refilling it when dishes were not coming clean.
I poured 2 litres of hot water into the salt reservoir.
I then put the empty machine on the intensive 65 degree wash, half load and with the reservoir cap still OFF.
When finished I filled up with salt and HEY PRESTO the salt light is OFF!!!!
Just hope it stays that way until the reservoir really needs refilling.
While I was down on my hands and knees I took the opportunity to clean the filters in the sump. They do get full of bits!
I also flushed the sump by dashing a couple of cups of hot water into it and then bailing it out with a small yoghurt pot. I repeated this until the water in the yoghurt pot and the sump no longer had any signs of bits in them. (Dashing = vigorously pour)
I was amazed at how many bits I got out, especially considering I had given the machine a good clean in the past 6 weeks.
I even got part of a paper label!
So there we have it, try it out and report back.
Sep 14, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit idl 705 Dishwasher
Having read another users fault (LUNNY) that has same fault. They got engr out and it was a blocked pump. Where is the pupmp located on this model as I have the same fault and want to resolve it asap.
Aug 24, 2006 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit 24 in. IDL700 Built-In Dishwasher Logo
837 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
