Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Washer/dryer The machine does not finish a wash,then the programme selector knob keeps turning,then the on/off indicator constantly flashes.
  • Anonymous Nov 26, 2007
    nf comes up and washer stops
  • hemiboy426 May 11, 2010
    Did cleaning the filter work?????
Open the filter on the bottom of the machine (water will empty out).  Clear any blockage.
Posted on Oct 15, 2007
Wd2000 washer dryer combo timer advances around timer
If the program selector knob keeps turning, the machine needs to be reset.
Wait a few minutes for the drain pump to empty the tub, switch the washer-dryer OFF. Select one
of the Reset positions on the knob, then switch it back ON.
The link below will take you to the manual.
Hopes this helps.
Oct 12, 2014 | Splendide 2100 Vented Washer-Dryer
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
Mar 13, 2011 | Indesit W 123 Front Load Washer
What does it mean when the selector knob on washer keeps on turning when you have a wash in and also it does not spin i have to put it on drain to take clothes out
try selecting wash programme before switching power on to machine, as often with indeset if you move timer while on this will happen
Feb 13, 2010 | Indesit WA 125 Front Load Washer
Selector knob on my Indesit Washing Machine WI 121 keeps turning & light flashes twice before light turns off. This happens approx 4 times in a whole turn of the knob. Indesit want £100 to come out to fix!...
Sounds like you have faulty control module, which is quite expensive to replace.
Also the E.P.R.O.M would have to be replaced as well.
Probably cheaper to buy new washer.
Good luck.
Nov 18, 2008 | Indesit W 123 Front Load Washer
Programme Selector knob keeps turning. - Airston Margherita AB95
turn knob to solid dot then leave it for a little while to reset then turn it onto the desired cycle
Jun 02, 2008 | Washing Machines
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
486 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
