i had the same problem, but was able to fix it by opening the brush compartment and cleaning the brushes, then separating the brush head from the body of the vacuum and hitting the reset button at the top of the brush compartment (per dyson online instructions).
Works perfectly now.
Your machine may have A clutch fitted,
When you pull handle back to vacuum csarpet ensure that the brush control dial moves to drive. If it is stuck in park or stop rotate the dial by hand to drive the roller should now rotate.
If it doesnt then chances are that one of the two clutch belts has snapped. You will need to remove the clutch in order to rectify this fault.
Have upright bagless (can't find model number - has Dyson Foot 8 on front !). Is still picking up...
(More)
Have upright bagless (can't find model number - has Dyson Foot 8 on front !). Is still picking up but makes horrendous rattling sound. Have taken off all bits that come off but can't find problem.
dyson brush won't stay flat on carpet...I need to have the vacuum almost upright for contact to be...
(More)
dyson brush won't stay flat on carpet...I need to have the vacuum almost upright for contact to be made to vacuum...this is a problem ...simple fix?
Dyson DC7. Problem:- switch the hoover on and it cuts out after approximately 1 second. Any ideas...
(More)
Dyson DC7. Problem:- switch the hoover on and it cuts out after approximately 1 second. Any ideas please?
