Question about Microsoft Office Standard for PC
Excel I need to find a formula that will tell me how to calculate and automatically change the number of items and the left overs in singles rather than in fractions or percentages. As an example I have 235 items and they will be divided by lots of 25 so I will have 9.4 but the .4 doesn't work out to single items. The .4 should work out to 10 rather than the percentage. Can you help me?
    Problem Solver:
  • 5 Answers
If your A5 cell contains 235 and B5 cell contains 25 Then type following formula in cell C5 = Roundup(A5/B5,0) this will give you answer 10 .Other wise you can put formula in cell D5 as Roundup(C5,0)and in C5 put A5/B5
Posted on Oct 10, 2007
What is formula to find percentage of females in my workplace?
      To get around this, you can calculate your numbers as percentages first. For example, if you type the formula =10/100 in cell A2, Excel will display the result as 0.1. If you then format that decimal as a percentage, the number will be displayed as 10%, as you 'd expect.Aug 2, 2011
      How to do percentages in Excel - Office Blogs
      https://blogs.office.com/2011/08/02/how-to-do-percentages-in-excel/
    Feedback
    How to Calculate Percentages in Excel
    www.excelfunctions.net > Excel-Formulas
    Two Percentage Calculation Types. Calculate a Percentage as a Proportion.Calculate Percentage Change. Displaying Percentages in Excel Cells ...
    Excel formula: Get percentage of total ' Exceljet
    https://exceljet.net/formula/get-percentage-of-total
    Excel simply divides the values in column C by the total in C11. For the formula shown, the result is the decimal number .63. Because the Percentage number format is applied to cell E6, Excel displays .63 as 63%.
Jan 19, 2016 | Computers & Internet
In Excel adding positive and negative numbers
Yes,
  1. Select the column. (click on top of the column it will select)
  2. Right Click and select Format Cells.
  3. Select Currency in Category then press OK
b6298df.gif Now just type your Numbers i.e. 571 for $571 and -650 for -$650 and sum using the normal way.
That is Select the Cells which you want to SUM and Press Alt+=
This will bring the total just below the selected cells.
Thanks
Iqbal
Apr 02, 2008 | Computers & Internet
What are the formulas in grading the grades uisng microsoft excel
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
  1. All formulas begin with an equals sign (=).
  2. Some formulas use operands such as +,-, *,/ for addition, subtraction, multiplication or division.
    For example, the formula =A1+A2+A3 would add the contents of cells A1, A2 and A3.
  3. Other formulas refer to different functions such as SUM, AVERAGE and others.
    For example, the formula =SUM(A1:A3) would add the contents for the range A1 through A3.
  4. Formulas can be combined with operands.
    For example, the formula =10*SUM(A1:A3) would add the contents cells A1 through A3 and multiply them by 10.
  5. Functions can be nested within each other.
    For example, the formula =SQRT(10*SUM(A1:A3)) would take the square root of ten times the sum of cells A1 through A3. When functions are nested, it is important that the number of left parentheses match the number of right parentheses.
Aug 19, 2011 | Microsoft EXCEL 2004 for Mac
Steps to figure out formulas in excel
Hello this is Baris,
If you forget about the numbers and start naming your cells you can figure out your own formulas... Example :)
You buy apples, and you pay $2 per piece
in this case you have 2 numbers to find out how much you will pay.
price per apple
quantity
you have 3 apples you pay 6 dollars very simple right. 2 times 3.
Same thing in excel but this time you will just say price times quantity and excel will do the calculation for you.
Lets name your cells
Type in A1 Price
Type in B1 Quantity
Type in C1 Cost
Now, Column C is your calculation area.
Type in A2 2 (price for apples)
Type in B2 3 (quantity of apples)
Type in C2 =A2*C2 (price times quantity)
Now on, you don't have to calculate anything. You can change you price and quantity, cost will change by itself. Because the value in that cell is now related to other values in A2 and B2. I hope this gives you a starting point.
Sep 30, 2009 | Microsoft Excel for PC
Formula for excel to calculate years of giving.
In AJ3 thru BT3 put a number. Doesn't matter what number. Then type the following formula into a cell and instead of pressing enter press and hold control, then press and hold shift, and then press enter, and then release all the keys.
=COUNT(IF(NOT(ISBLANK(AJ2:BT2)),AJ3:BT3)
Jun 03, 2009 | Haier Chest Freezer HNCM070E
Writing a formula for a sumif problem
Brenda,
Your problem is not so much the formula but the cells that contain the hours for each call. Since they contain the text “hrs” (for example “2.25hrs”) this turns the whole cell to text, not numeric, which will always add up to zero in Excel. So do two things:
- Change the cells in column H (Time Spent) to numeric (2.25 instead of 2.25hrs) – you might want to change the column header to Time Spent In Hrs just to b clear
- Use this formula =SUMIF(E8:E26, 1, H8:H26)
For the formula change the middle number to correspond to the operator ID – for example for operator 2 change the formula to =SUMIF(E8:E26, 2, H8:H26)
This should do it.
BTW, sent you a similar email about this.
May 07, 2009 | Microsoft Excel 2007 Home and Student...
Need a range answer in excel
Yes, Concatenate is the name of the formula.
ex:
=CONCATENATE(.15*B27," to ",.25*B27)
Which would return something like: "15.1254 to 25.5514"
If you want to limit the numbers in the returned data to whole numbers, you need to add the Floor formula.
ex.
=CONCATENATE(FLOOR(.15*B27,1)," to ",FLOOR(.25*B27,1))
That would return something like "15 to 25"
Dec 19, 2008 | Microsoft Excel for PC
Can't reopen circular reference file in excel
  1. Click the Microsoft Office Button , click Excel Options, and then click the Formulas category.
  2. In the Calculation options section, select the Enable iterative calculation check box.
  3. To set the maximum number of times that Excel will recalculate, type the number of iterations in the Maximum Iterations box. The higher the number of iterations, the more time that Excel needs to calculate a worksheet.
  4. To set the maximum amount of change you will accept between calculation results, type the amount in the Maximum Change box. The smaller the number, the more accurate the result and the more time that Excel needs to calculate a worksheet.
Nov 05, 2008 | Microsoft Excel for PC
Excel formula
The formula should go like this:
=IF(C11>40,(C11-40)*D11,0)
This one will give you the result of (ONLY overtime hours)*(hourly wage), and if there are no overtime hours the result is 0.
Now, if you need to multiply that result with say 1,5 or whatever - insert the number you need like this:
=IF(C11>40,(C11-40)*D11*1.5,0)
If you need more help, please ask.
Sep 14, 2008 | Computers & Internet
Formmulas are not appling in the excel of office xp
Dear chidambar, thats usually because you've mistakenly tampered with a file or because you're putting an inapplicable value. Can you tell me what error is it exactly ?
you might like to re-install your MS excel after backing up your files. You might also like to repaire your ms office from your cd.
if that has helped you plz press fixya.
Dec 13, 2007 | Computers & Internet
Microsoft Office Standard for PC Logo
253 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
