Dell 946 printer - unable to print
Hi, I have a new dell inspiron 1520 laptop and dell 946 all in one printer. However, I'm unable to print. I've tried all the fixes suggested (ie check usb connections, power on/off, adjust firewall settings, restart laptop) but nothing has worked. When I check settings in the control panel everything looks fine. I'm running Windows Vista with McAffe and Windows firewalls. Thanks, Rod
  • 1 more comment
  • Anonymous Nov 05, 2007
    I am geting the same error - tried the lot - the 'test page' prints out but nothing from MS Word.
  • Anonymous Nov 28, 2008
    You would think that Windows Vista would step up and attempt to fix the problem. Evidently, there's not enough money in it for them!
  • Anonymous Nov 29, 2008
    unable to print
SOURCE:
SOURCE: Dell 946 AIO printer won't stop beeping after firmware update attempt
I just experienced this problem today. The beeping means that when you tried to update the firmware it damaged the printer internally. I would have to assume there is some kind of chip in there that can be flashed and it got cooked by the firmware update. Dell is sending me a new one.
Posted on Apr 06, 2008
  • 398 Answers
SOURCE: computer will not communicate with printer
Go out to Lexmark web site and look for a vista update in their software download section. So this should solve your problem.Most of the cds which come with equipment do not contain vista software and drivers.
Posted on Aug 06, 2008
  • 1605 Answers
SOURCE: Dell 946 Won't Print
turn off the printer.
disconnect the printer from the computer.
restart the computer.
conencted the printer after the computer is up, and all applications are loaded.
the computer should inform you the printer is connected.
send a test page to the printer.
done
Posted on Nov 13, 2008
  • 54 Answers
SOURCE: lexmark 5470 printer not working on Windows Vista
If you just connected the printer to your Vista PC, the drivers probably didn't load.
If you haven't yet, you need to install the Lexmark drivers first before you can use your printer. Unplug the printer before installing, then plug it in when prompted by the software.
Lexmark drivers:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on Mar 26, 2009
  • 85 Answers
SOURCE: Dell Color Printer 725 - Communication Not Available
I have seen that in most of the cases (with lexmark and dell printers) it is fixed by reinstalling the printer software. Be sure that you completely remove the older drivers using the cd or using add/remove programs.
Posted on Jul 29, 2009
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Describe your 946 All-In-One InkJet Printer Problem I'm running windows 7 on a Gateway laptop and managed to get it to print at one point but then installed some other items to get it to recognize...
This printer is not a wireless rpinter, so I guess you were trying to attach it to a print server of some type.
Try using these Recommended Wireless Router Settings,I use channel 11. I would make a new SSID to make connecting easier.
If your computer came with Windows 7, then follow the procedure below. If you upgraded your computer, the did you install the chipset drivers first. If using a Dell Computer that was upgraded, the desktop/notebook system utility and the chipset drivers need installed first or the rest of the drivers will fail to install. How to Download and Install Drivers in the Correct Order
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 946 Photo All-In-One Printer owners thread (W7)
Virus programs and firewalls will block communications.
If you need more help, please post in the Dell Printers Forum
Rick
Aug 24, 2011 | Dell 946 All-In-One InkJet Printer
Hi there I have lost the install CD and would like to install my Dell all in one 946 printer to my new laptop. I runs with windows 7, and the software I have downloaded from the internet does not seem to...
Click here to download the driver for dell all in one 946 printer. First uninstall the previous drivers and then install this driver.
If you like the post please leave your feedback and ratings.
Thanks in advance.
Oct 04, 2010 | Dell 946 All-In-One InkJet Printer
Just got a new lenovo laptop and my dell 946 will not print anything from it. Not sure if it's a compatability problem?
Did you install the DELL printer-driver software onto the new laptop?
If you've lost that CD-ROM, access the manufacturer's web-site:
http://support.dell.com
and enter '946' and do a search for the device-driver software.
May 14, 2010 | Dell 946 All-In-One InkJet Printer
Hi, try uninstalling and reinstalling the drivers for your printer and ensure that the printer its detected. If it is detected, contact printer support for troubleshoting. It is a possible issue with the printer. :)
Mar 26, 2010 | Dell 946 All-In-One InkJet Printer
How to Unlock Dell inspiron 1520 Laptop Password
I is my understanding that you can contact Dell with the service tag, and express code and get the master password to clear forgotten passwords.
May 09, 2009 | Dell Inspiron 1501 Notebook
Dell 946 printer
You need to set the size of your page on the printer preferences.
If you need more help you can see the manual of your printer here: http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Sep 07, 2008 | Dell 946 All-In-One InkJet Printer
Open Questions:
DELL PriNtEr Tollfree [email protected][+1-855*536.5666]NuMbER #OO#&%,& VIRGINIA Inferior security at FIXYA and 6YA leave your financial and bankcard data and personal passwords at risk of being sold by cybercriminals in India. Toronto-based VerticalScope Inc. says six of the community websites it administers were hacked last month in the latest of a recent series of data breaches affecting Canadian online user information. The company says in an emailed statement an “unauthorized party” gained access to community member data for six of its websites on Oct. 17 and 21 and some of the data was disclosed online. It says the data did not include credit card or banking information but did include usernames, email addresses, encrypted passwords, user identifications, registration dates and IP addresses for websites including DIYchatroom com, PBnation com, HysterSisters com, ToyotaNation com, JeepForum com and WatchUSeek com. Alex Holden of Hold Security, LLC, says his American cybersecurity firm was able to intercept hackers’ attempts to sell data stolen from VerticalScope and tracked down screenshots containing current secure information to confirm the breaches had taken place. He says the attack was “rather sophomoric” and its success doesn’t reflect well on VerticalScope’s cybersecurity readiness, adding it’s unclear how many people had their confidential information stolen. VerticalScope, which is majority owned by TorStar Corp., says it has caused all of the passwords on the sites to expire and has notified affected users. It says the breach has been reported to the federal Privacy Commissioner, Toronto Police Service and the RCMP cybercrime unit. About 8,000 Canadians had personal information and, in some cases, credit card information, exposed in the massive Equifax cyberbreach that occurred in July but wasn’t reported until September.
Oct 14, 2019 | Dell Office Equipment & Supplies
Have you received notification that your financial records have been stolen, and a credit check reveals *****? Equifax tracks stolen information but you may not know yours was sold by hacker spammers. Inferior security at FIXYA and 6YA leave your financial and bankcard data and personal passwords at risk of being sold by cybercriminals in India. Toronto-based VerticalScope Inc. says six of the community websites it administers were hacked last month in the latest of a recent series of data breaches affecting Canadian online user information. The company says in an emailed statement an “unauthorized party” gained access to community member data for six of its websites on Oct. 17 and 21 and some of the data was disclosed online. It says the data did not include credit card or banking information but did include usernames, email addresses, encrypted passwords, user identifications, registration dates and IP addresses for websites including DIYchatroom com, PBnation com, HysterSisters com, ToyotaNation com, JeepForum com and WatchUSeek com. Alex Holden of Hold Security, LLC, says his American cybersecurity firm was able to intercept hackers’ attempts to sell data stolen from VerticalScope and tracked down screenshots containing current secure information to confirm the breaches had taken place. He says the attack was “rather sophomoric” and its success doesn’t reflect well on VerticalScope’s cybersecurity readiness, adding it’s unclear how many people had their confidential information stolen. VerticalScope, which is majority owned by TorStar Corp., says it has caused all of the passwords on the sites to expire and has notified affected users. It says the breach has been reported to the federal Privacy Commissioner, Toronto Police Service and the RCMP cybercrime unit. About 8,000 Canadians had personal information and, in some cases, credit card information, exposed in the massive Equifax cyberbreach that occurred in July but wasn’t reported until September.
129 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
