Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
Bad directsound drive
My speakers can't play.
There is no sound in my computer
Posted on Mar 26, 2008
  • 102 Answers
Could you explain a bit more? Tell us the things you've tried.
Posted on Oct 07, 2007
Computer say bad directsound driver
BAD DIRECTSOUND DRIVER, you install your sound card driver properly and use CODEC PACK to support any audio and video format...
Jun 22, 2009 | Intel Motherboard
Bad direct sound driver error 88780078
1.) Open Winamp
2.) Press and hold down Ctrl+P (for preferences)
3.) Go to Plug-ins --> Output
4.) Double click on "DirectSound output"
5.) Click on the Driver tab
6.) Make sure the device in the drop-down list correctly reflects your soundcard.
Further DirectSound config tweaks....
http://forums.winamp.com/showthread.php?...
This may just do it for you folks...please leave rating, thank you kindly
Apr 25, 2009 | Computers & Internet
I think I need a driver for a Mikomi headset with mike.
mikomi head and mic set drivers for xp pro meed pls
Mar 18, 2009 | Audio Players & Recorders
Today,I open a song to listen it but when i play the song with winamp the message come that bad sound speaker and error 88780078
That is a Bad DirectSound Driver Error. If the problem persists, make sure you have the correct sound card drivers installed. Also try downloading and installing the newest driver for your hardware.
If you click on Start, and then Run... type in dxdiag and press ok.
This will bring up DirectX where you can run some test with your soundcard.
Mar 03, 2009 | Audio Players & Recorders
Bad DirectSound driver. Error code:88780078
check the sound drivers in device manager. if it gives yellow sign then re-install sound drivers.
Nov 29, 2008 | Computers & Internet
I need help to solve this ''Bad Directsound Driver''.
download and install the latest " Microsoft direct X " which I think is version 9
Nov 21, 2008 | Intel 845GE Motherboard
No sound
you change your speaker ........then install your motherborder driver
hope some virus in your pc ....scan it.
Sep 06, 2008 | Microsoft Windows XP Home Edition
Sound problem
I have a creative SoundBlaster LIVE! 24 Bit External Sound Card and this annoyed me for weeks.
depending on your surround sound reciever depends on the solution.
i have an Acoustic Solutions surround sound system with coxial and optical inputs, aswell as stereo red & white jack inputs.
not knowing the method or connection your using makes it difficult to give you a single solution so i'll list a few.
The soundblaster software shoudl include the Creative Audio console with all sorts of effects, one is CMSS (CMSS-3D) Stereo widening which is still stereo but gives a surround sound effect.. but i'm guessing you payed for 5.1 and you want 5.1 onto the next part
5.1 surround sound can only be produced when the actuall audio your playing contains 5 channels of audio, for example you cant play a stereo song in 5.1 surround sound without some sort of hardware or software sound manipulation. Luckily my surround sound system has Pro Logic II built in and some other effects which convert a 2.1 signal to a 5.1 signal and it works brilliantly. I'm not sure of a software alternative.
setup for your soundcard will be different under XP and Vista also, but there should be a properties option for your sound device where you can select your speaker setup such as headphones, built in speakers, 2.1 speakers, 5.1 speakers, 7.1 speakers and you should be able to manage this from the creative software.
If using Coxial / Optical or SPDIF under vista you MUST set the playback device as SPDIF, at least you have to with my sound card and drivers and seems to be a limitation of the actual sound card drivers for vista.
Personally i was looking forward to hearing the windows login melody in 5.1 surround sound too, but this doesnt happen.
Infact i find that almost all programs bar a few will not play Dolby Digital or DTS 5.1 surround sound via any or my output options hence the next solution..
if you have the 5.1 sound but winamp simply just plays it in stereo try the following.
You need to use DirectSound Output:
Preferences (Ctrl-P) > Plug-ins > Output > Select "DirectSound Output"
That should work in most cases, but if not, then:
Checkmark: "Allow hardware acceleration" in DirectSound Output config,
and make sure your sound card/chip is selected as Output Device.
Note that any changes will take effect only after playback is restarted.
In some cases, a Winamp restart is required.
If that doesn't work make sure you have the latest version of DirectX
(v8.x or higher is required)
Winamp 5.25/5.3 and higher:
For actual multi-channel files (ie. aac/wav/ac3/ogg/wma files encoded in 5.1ch surround, as opposed to standard 2-channel stereo mp3's), you need to checkmark "Allow surround sound" in 'Winamp > Prefs > Playback' for the music to play in its original 5.1 channel format (Note that this setting is checkmarked by default).
Windows Vista:
In addition to the above instructions, Vista users will also need to go to:
Control Panel > Sound > Playback tab > Speakers > Configure:
Select: 5.1/7.1 Surround.
Then:
Control Panel > Sound > Playback tab > Speakers > Properties > Enhancements tab
and checkmark "Speaker Fill"
Hope this helps
Anthony Kinson
Apr 22, 2008 | Audio Players & Recorders
First, go to control panel, and then device manager, to see if any problems exist. If not, still in control panel. go to check sound. Click on Manage Audio devices to see if all is ok. If you need to redownload your sound controller, like realtek, or it needs an upgrade, you can download that from your computer's support website. You also can check to see if you have configured your system to your speakers==are you using built-ins, or have you purchased others? Let me know if this does the trick for you.
Apr 05, 2008 | Audio Players & Recorders
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
47 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Shawn DuRee
Damen Wong
Damen Wong
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
