Question about HP Compaq Presario V2000 Notebook
Installing OS I am trying to install OS windows XP pro on my notebook and whenever i try to install in between of the setup my notebook shutdowns and thus I am unable to find a solution. I lost the CD's that come along with the laptop.
  • saberz Jun 03, 2008
    my compaq presario v2000 display "a read disk error occured" on screen and cant boot properly. i WONDER if my hard drive just get loose from the board or it is just broken from being old. It happened while im using my laptop playing an online game. But when i try booting from cd rom, the laptop also display the same message. I WISH to know what should i do. will changing hard drive solve the problem or is there another real problem?? i may also need driver stuff since i lost the initial disc. please provide me a place to download driver stuff. i wish to hearing from you. (indra - [email protected])
Http://www.filepanda.com/get/yk0cruqn/ drivers for compaq v2000
Posted on Oct 08, 2007
SOURCE:
I use hp nx9010, i want to re-install windows xp but any time i try, the machine shutdown. sometimes is able to move up to copping files sometimes not then shutdown; i don't understand why is only windows...
well that is so easy to answer,
first off you are not using real HP disks are you.
sure. its old Blue Microsoft disks right,
and when you do that wrong, you get no HP chip drivers and lost more missing, even top row, fn keys dead, not just audio.
XP is a dead OS. for 3 years now, zero updates and is now a virus magnet extream.
nx9010 note book shuts down, all 3 os install different. !
old XP runs a very old and very DUMBB seteup.,exe
the newer OS run WINPE for setup.exe. vastly better and boots and loads the OS totally different.
Xp can be installed many ways, not one stated by you.
1-insert, HP install disk in CDROM drive and click, setup.exe running in a XP explorer window, live install
2: boot to HP install disk.
3: boot and hit F11 run HPs on HDD restore partition.
4: same as a above 1, or 2, but is Micro soft disk (wrong, you did it wrong, do not use mS disk) if must ask how, its a long long long story. ive done it all ways, 1000s of time. now since first PC.s ever.
if booting to XP , right or wrong CD. (its a CD right<)> or a stick
that too not stated,
it boots and you answer questions, then it starts copying
if it stalls that means, the CD is bad.
or PC is bad, you do know there are 3million transistors here to fail right? bad HDD, bad Mobo, and more. lots more
even the CPU can over heat and will shut down.
Personally I avoid all CD nows, they sux'd then and do now more.
make and ISO of your CD, (ask its easy and free)
then burn the ISO to a 4GB or bigger uSB memory stick using free RUFUS app.
boot to stick. on my HP hit F9 and pick Udisk USB. boot
bingo no more CD errors ever again.
i bet bad CD. seen it vast times, endless , but not today. too savvy now. to mess with any CD, if you copy it to ISO and get CRC errors
its a bad CD.
end pain.
the problem with real old PC most cant boot to USB
or must be BIOS flashed updated to get that.
ill now ill try to learn what yours can or can not do.
lacking ,what is there now.
but id do this first. go in to BIOS BOOT PAGE
What is the default boot order? The default boot order settings for the computer are configured in the factory. The default boot order for HP notebook PCs is listed below.
  1. Floppy disk drive
  2. Optical drive (DVD, CD-ROM)
  3. Hard drive
  4. USB device (see this?) bingo, can boot and install any OS here
  5. Network adapter
Apr 23, 2017 | HP NX9010: Pentium 4-2.4 GHZ, 512MB...
How do I install windows xp pro sp3 on my Toshiba L355 S7812 laptop? Each time I try to install windows setup can not find the hard disk.
Check in your bios if it sees your HDD in there, typically it is F1, F2 or DEL key while posting.
Is the laptop running an OS?
Jan 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
Windows could not start because the following file is missing or corrupt: WINDOWSSYSTEM32CONFIGSYSTEM. I try to repair it by using setup CD-ROM recovery consule but setup fails stating setup did not find...
Hi
I wanted to know which os you are trying to install on this model if it was installed with vista os and now you are trying to install the xp
You will get this type of issue
Check for the SATA Native support in the BIOS
> To Check in BIOS - Shutdown the notebook as soon as you power on the notebook keep tap on F10 key - go - to - system configuratoin- check for the SATA Native option - status should show as Disable.
> Then also if fails - Scan for the Hard Disk drive in the bios
Select - Diagnostic- Run long and short hdd test.
With Regards
[email protected]
Apr 09, 2009 | HP 435768-001 - Compaq Presario C300...
Xp pro sp3 setup problem for optional windows components
It looks like you have a copy of Zone Alarm on your PC and Windows XP Pro SP3 is not liking it. One thing that you can try is to disable Zone Alarm by right clicking on the icon that it creates on the lower right hand corner of the screen and see if you can find a "disable" or "shutdown" option. After doing so, then try to install again. Another thing that you can try is to completely remove Zone Alarm, try to install SP3 again, and if it installs, re-install Zone Alarm. However, I think the easiest path is to disable Zone Alarm temporarily. Let me know if this helps you or not.
-Serge
Mar 30, 2009 | Microsoft Windows XP Professional SP3 Full...
Windows xp on acer aspire 4315 cannot shutdown normally
ARE YOU SAYING YOU SHUT DOWN WITH THE POWER BUTTON.GO TO START RUN AND SHUTDOWN OR RESTART THERE.RICHARDM69
Dec 05, 2008 | Acer Aspire 4315 Notebook
Remove Vista OS and Replace With XP Pro
1. make sure your laptop is set to startup from a cd
2. after laptop finds the bootinfo from the cd and asks you to press any key to start from cd, press any key and xp setup will start.
3. in xp setup your going to need to delete your vista partitions, preferably all partitions and then proseed to install xp into a new partition.
4. proseed with the windows setup follow the instructions and configure your settings as you wish.
Mar 17, 2008 | Acer Aspire 5100 Notebook
HP NX9010 automatically shutdown
Definitely a software problem, somewhere along the installation process, the data on the CD is being read wrong. Try a different installation disk, and see if this fixes the problem. If not, then it could be that there is either a problem with the CD drive, or the IDE controller for the Hard Drive.
Feb 25, 2008 | HP Compaq Business Notebook NX9010
Error number 25502 and 25510
Hi manish,
You got incompatible OS version, office xp requires most files from WinXP, sorry to say that it will not really work.
tnx
-micro
Feb 10, 2008 | Microsoft Windows 98 for PC
Installing new OS
Every laptop is accompanied by a preinstalled vesion of Windows, on the same hard disk in a hidden space. So if you get a prompt to restore your laptop to a previous state at the beginning of system startup, press the relevant key. If windows xp is your choice. and want to install it you may need follow the installation instruction from your system manufacturer. When the system starts up some information is displayed on the screen, like this: " Press F1 to enter setup" If you press the relevant key and enter the BIOS setup you can find the CPU temperature settings, shutdown temperature etc... This may not be you case. So I suggest you to get support from a qulified technician. Your system hardware should have some problem. (motherboard or hard disk is more prone to error) you can also try to find information from your system vendor's manuals and support website. All the best
Oct 03, 2007 | IBM ThinkPad A21m 2628 Notebook
HP Compaq Presario V2000 Notebook Logo
52 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
