Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 43PP8545 I have a Philips Rear Projection TV that turns on but has no sound and picture. The screen remains blank and the power relay sounds like it is switching on and off.Also LED lights on front of set.continu noise creates either in power section or flyback section need helps
  • navoor Nov 11, 2007
    I have philips rear projection tv 43pp85645. The sound is ok but no picture.
    The screen remains blank with out picture or light. Please any body help me why this is happend and what part is to be replaced?
  • hdtv lover Mar 20, 2008
    I have both sound and picture on my TV (philips 43pp8545) except that the picture and text is warped and doubled at the bottom and top of the screen. There are also red lines, some bent (bottom and top of screen) and some straight (middle of screen). Has anyone experienced this kind of problem with this model and if so, how did you resolve it?
    hdtv lover
    Problem Solver:
  • 10 Answers
Sound like you have a problem in the deflection area.
Get if the horizantal output transistor short.
Posted on Dec 22, 2007
    President:
  • 4,402 Answers
The most common problem is convergance amp ic, but with out troubleshooting it's hard to pin point whats wrong.
The quick answer to you problem is critical in what your set was doing prior to it shutting down. Do you remember it having a Color problem like alignment of convergence? Was the sound cutting out on you? Or was there part of the picture missing? If one of these then you could eliminate time and money. To be honest you would save money DIY. You also can call PTS at 18008447871 and get the price on Deflection board or Large Signal, whichever has High Voltage Transformer on it and price. This will save timePhilips 43PP8545 - 1.gif troubleshooting2.gif, because it takes the knowledge of knowing voltages, components, etc. Which require skills the average person may not have. Hope this helps!
Posted on Dec 14, 2007
SOURCE:
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
No Picture, No Sound
You can get a repair kit from www.magnavoxhelp.com for under 30.00 dollars.
Jun 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
No picture, sound ok
you need a new flyback.
that is the problem.
Nov 11, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
When tv turned screen is blank and chirping sound comes from back
A chirping sound usually means that one of the secondary supplies has shorted, most likely the horizontal output transistor. The power supply "chirps", which is the sound it makes when it protects itself from drawing too much current. The set should be serviced by someone with experience in Philips projection TV'.
Jun 21, 2007 | Philips 43PP9202 43" Rear Projection...
Have sound...but no picture!
check the video circuit or the flyback.they could be defected.good luck.
May 16, 2007 | Philips 7P5441C 54 in. Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
148 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
