This problem should be removed because:
Problem with Air Conditioners
manual air duct damper installation
I want to install a "manual air duct damper" to control the air flow in my HVAC system. How do I do that?
Solutions (1)
Go down to where the ducts come out of the furnace. Identify the line you want to install damper. Open duct and drill two holes directly across from each other. Take your damper and undo the nut and washer on the one end and install in the holes you just drilled. Reattach the washer and nut and now re connect the duct seal it with duct tape and you will be good to go.
If you have 6 inch ducts get a 6 inch damper. But be sure to do everything at the beginning on the duct as to divert air to other ducts.
I have to tell you that changing your air flow could develop problems if you do very many ducts. So be very aware of what you doing. All systems are put in with air flow in mind.
My hvac duct work on
My hvac duct work on one of my central air units has a lot of condensation and causing puddles of water throughout my basement. Do you know...
Carrier Air Conditioner Infinity System - Air...
We had a carrier infinity system put in place 2 years ago. A week a go we had a system failure and notification on our screen for system...
Trane Heater A/C Airflow Control
I have a Trane XV90 with a Trane RXC065 A/C unit - a fairly high end residential system. I'm looking at options for air flow control,...
I have the following equipment
I have the following equipment installed in my home Carrier Furnace 58MV Air Con 24APA7 Humidifier SBP Air Purifier GAPAB Carrier Control...
Add Your Solution
Fix-O-Meter
2,002
2,002 people viewed this problem
- 0 people are following this problem. Be the first!
Top Air Conditioner Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
