Question about Samsung SH-S182D DVD RW Dual Layer Burner
Samsung DVD writer SH-S182 problem
The Burner does not close discs. when i burn data DVD's with nero, the burning and verification completes successfully, and I can browse the disc in explorer, but when I eject and insert the burned DVD again, windows considers it as a black disc.
  • 3 more comments
  • Anonymous Dec 06, 2007
    after I burn a disc , my dvd drive seems to read it as a blank disc when I reinsert it.
  • shayc Dec 21, 2007
    I found a solution by updating the firmware - windows recognized it now as a DVD RAM drive and not as CD drive and it detects all CD's. You can download the firmware from samsung site
  • rocky-g Apr 13, 2008
    I HAVE A SUMSUNG TOSHIBA TS-H652 WRITER FOR A YEAR ALREADY IT'D WAS BURNERING PRETTY FAST,BUT FOR SOME REASON IT HAS SLOW DOWN , SO I TOOK OFF OF MY PC AND PUT IT INTO MY DUPLICATOR USEING THE USB AND BURN REAL FAST,IPUT BACK INTO MY PC AND STILL BURN SLOW,WHAT COULD THE PROBLEM
  • Anonymous Apr 24, 2008
    when i burn data DVD's with nero7, the burning and verification completes successfully, and I can browse the disc in explorer, but when I eject and insert the burned DVD again, windows can not read it.
  • Anonymous Mar 18, 2014
    samsung multi recorder
Try a different power connector from psu,do not share same as HD!!should work!!
Posted on Dec 10, 2007
SOURCE:
Installed Samsung SH-182 SH-S182 DVD Burner But my computer windows XP is not reconizing the newly installed unit
Which OS Service Pak is XP using? Have you tried to update the drivers? ' System ' Hardware ' Device Mgr
Can you test the burner on a 2nd PC? My older PC's dont see the DVD-RW but the burning software does.
Feb 21, 2011 | Samsung SH-S182 DVD±RW Dual Layer Burner
Dvd takes forever to burn on my dvd drive and I use nero as the burn software either the burn process fails or it take around 10 hours to burn a dvd at 16x
I would recommend trying a firmware update on the drive. What type of computer do you have? For example, HP has specific updates for drives at http://www.hp.com Otherwise, go to samsung.com and go to drives/downloads and search for what is called a "firmware driver" (firmware is software on the drive that will help it to either work better, or confirm you have a defective DVD drive.)
Nov 06, 2010 | Samsung SH-S182 DVD±RW Dual Layer Burner
I require the driver for Samsung SH-S182 DVD±RW for my Home -System since my device manager is reporting the same was missing or corrupted.
You can find you driver here :
http://www.opendrivers.com/driver/240991/samsung-sh-s182m-dvd-writer-firmware-sb06-windows-98se-me-2000-xp-free-download.html
Oct 29, 2010 | Samsung SH-S182 DVD±RW Dual Layer Burner
Hello my samsung sh-s182 dvd -+rw doual very slow burn [email protected]
First look and see the write speed of the drive. 1x to 4x is slow but recommended by all programs and this is initially the default settings for most programs. You must goto the settings of your dvd burning program and set the burn rate to 16x or higher.
Sep 25, 2009 | Samsung SH-S182 DVD±RW Dual Layer Burner
DOES SH-S182 DVD WRITER SUPPORT DVD-R FORMAT DISC?
Yes
Thanks, Frank
@Tech
3868607368
http://www.attechcomputers.co.cc
Jun 21, 2009 | Samsung SH-S182 DVD±RW Dual Layer Burner
Burned DVDs play on PC but won't play on home player. I have 3 PC (2HPs and 1 Parts built),running XP home, pro, media. I bought 2 Samsung SH-S182 DVD±RW Dual Layer Burner, and have tried them on all 3...
Nero 6 and 7 does not provides us the facilitiy of burning the DVD in appropriate DVD Format. Instead it burns the DVD in the normal DATA Format, which is not supportable by our DVD Player. To play the DVD in our DVD Player we should burn the DVD in the appropriate DVD Burner which itself converts the extension of the movie and make it proper for a DVD Player to read it. It also adds some files to the DVD which is sometimes used by the dvd player in running the DVD.
Thank You
Vinay Ramani
INDIA
Oct 07, 2008 | Ahead Software Nero 6 Ultra Edition...
DRIVERS NEEDED
All optical drives use ATAPI drivers, these drivers are native to Windows. Physically install the DVD player and it will be recognised, depending on what type of CD and DVD burning software you have your drive may not be recognised by them.
OEM burning software will only work with the optical drive it was supplied with, retail burning software should work with any drive.
Aug 31, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Samsung sh-s182 not read cd and dvd
To check, go into the control panel, systems, hardware, device manager and uninstall the dvdrw, then reboot the machine and let windows install the device driver.
May 09, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
SH-S182 installation
before anything else.. your computer must not be plugged in
have some screw drivers ready
open the case
remove the connections of your old cd/dvd-rom
remove the screws
remove the drive from the bay
replace it with your new dvd writer
replace the connections and the screws
put everything else back
then turn on your system :D
Nov 02, 2007 | Samsung SH-S182 DVD±RW Dual Layer Burner
Samsung SH-S182D DVD RW Dual Layer Burner Logo
1,427 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
