Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Replacing Door Hinge
I need to replace a broken door hinge to Hotpoint Washer Machine. How do I do this ? Do I need to remove the drum or can I access the internal clasp another way ?
  • 102 Answers
You should be able to access the back of the hinge via the top of the machine removed.
Posted on Oct 07, 2007
SOURCE:
Replace a door on a hotpoint washing machine
http://www.espares.co.uk/advice/washing-machines/a/7/1296/how-to-fix-a-broken-washing-machine-door-hing.html
Hi go to the above espares page where you will find a video on how to replace a door hinge, should show you enough to enable you to replace the door. There are other videos on how to replace the door interlock and release mechanisms as well.
Hope this helps, if it does please remember to rate me
May 04, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Plate at back of door hinge on hotpoint aqarius has fallen down
Tilt the washer back, and you will be able to retrieve the back plate from the bottom of the washer.
To refit it, you will have remove the front of the door seal from the cabinet front.
May 25, 2010 | Hotpoint Aquarius WD63 Front Load...
The hinge of the washing machine has broken - Creda W100FW
The door hinge block has fallen inside the front of the washer.To retieve it, tilt the washer back, and you should find it at the left hand side.
Remove all screws securing 2 parts of door together, prise apart with a screwdriver or similar, and the door will come apart.
You can now access the hinge and all other partsd inside the door.
Trust this helps.
Thankyou.
Nov 28, 2009 | Creda W100FW Front Load Washer
How do we fit a new hinge to a Hotpoint WM64P washing machine
Remove the wire clamp that secures the door seal to the front of the washer.
Pull the seal of the front. and double it back inside the washer.
Undo the 2 screws that secure the door hinge to the front of the cabinet, keeping hold of the hinge support plate behind the cabinet front.
Remove the door, and undo all the scews that hold the 2 halves of the door together, then prise apart the the 2 halves..
Replace the door hinge.
Reassemble in reverse order.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Washing Machines
I have bought a new door hinge for a hotpoin wd63p washer dryer but was wonderig do you have to take the front of the washing machine or the rubber
hi from uk easiest way is to turn off/remove water supply hoses disconnect power then remove top screws from rear panel(these also secure top panel if yo look ?) then lift rear of top panel slightly and pull back/then lift off you now have access to rear of front panel where door hing is secured by 2 screws from the front of panel/hing into a metal plate theaded inscrew door from plate whilst you hold plate thenremove door with hinge assy you will now see the inner plastic cover of door is secured remove this cover to access hinge screws renew hinge and whilst door is at this point might as well lift glass window and clean any **** around the edge ? reassemble in reverse to strip down hope this is clear enough for you ? good luck
Nov 04, 2009 | Hotpoint Aquarius WD63 Front Load...
How do I remove outer door hinge housing to replace with new one?
there are four screws holding the hinge on to the machine. two are visible in the hinge from the front but there are two inside the machine on the left side .turn off the power and water supplies drag the machine out from its place tilt machine back to allow a gap between the drum and cabinet then using a star shaped driver also called a Torx driver remove the two screw from the hinge and remove it.when refitting a magnetic driver is a great help to prevent dropping the screws into the machine a torch is advisable to see what you are doing I hope this helps
Sep 19, 2009 | Dyson Memory CRO1 Front Load Washer
Broken door hinge replacement on Hotpoint Ultima
Remove all the screws securing the 2 door halves together, and gently prize apart the two halves with a screwdriver or similar, be careful not to drop the door glass.. You will probably be better off removing the door from the front of the m/c altogether.
Replace broken parts as req'd.
Plz rate my solution
Thanks.
Dec 27, 2008 | Hotpoint Ultima WD72 Front Load...
Door Hinge Replacement
remove spring that holds the rubber bellows to front of machine
peel back and fish out plate from inside cavity of machine
then refit plare and reverse process
Mar 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
140 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
