Ssd won't show up as destination drive.
I'm not sure this is your problem, as you question isn't descriptive enough. But here's a solution if I do understand your question correctly.
When I have installed new hard drives in the past, I did the physical install, turned the computer on, and they just worked. Not so with SSDs I've installed. After the physical install, the SSD does not show up in the "Computer" window with all the other drives; because it's not FORMATTED.
Solution:
Navigate through:
Start > right-click on "Computer" in the right pane > select "Manage" > in the left pane select "Disk Management"
All the drives will show up in the main window, including the SSD you just installed. If it does not show up, there's a problem. Maybe one of the cables isn't fully inserted, or there's a defective cable, or a defective SSD.
You can tell the SSD from the other drives by the Gigabyte capacity, and also by the fact that it does not have an assigned drive letter (e.g. C:). Also, it's named something like "New Edition".
To continue to formatting, navigate:
Right click the SSD > select "Format" > select "Quick Format"
A drive letter will be assigned. You are given the option to change this letter if you want. Also, you are given the option to name this drive. This name will appear with the drive listing in the "Computer" window. I simply used the name "SSD", however if you want something more discriptive or colorful, it's your computer, it's your SSD, you can name whatever you want.
The other format option is for when one is installing a used HD which may have bad sectors. That option scans for bad sectors, and takes a LOT longer to format. Not necessary for a new SSD. Plus, you can scan a drive for bad sectors anytime with the "chkdsk" command.
The SSD is now ready for use, including for use as the main drive. Windows will happily load onto this drive.
