My printer is 6 months old. I came back from an extended holiday (turned all the power off before I went) an when I returned the printer stopped working. 1) fan or something is on cuz it's humming 2) all LEDs are on and NOT blinking
Any help would be great. the support guys at OKI weren't at all helpful.. Thanks.
-   Having th same problem. Used my printer 5 days ago just fine then went to use it again no power. Swapped it to another outlet and it came on. Ok problem solved, no. Returned to original outlet and again power came on. Hooked it back up to the computer, hit print, the printer icon came on the screen, the pages processed then the icon disappeared and nothing happened. No errors, nothing is blinking. On the hold now with Canon.
-   uptownmindi
Apr 08, 2008
-   stop working-   Guest
Mar 25, 2008
-   I have had my hp laserjet 3330mfp for 4 years and it's always worked great. Yesterday I came down to my home office and there is no power. My hp color printer is fine. I changed outlets and made sure the connections were good, but still no power. Anyone had this problem and found a solution?-   AtHomeAtWork
Solution #1
posted on Apr 22, 2008
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
ok my printer is not that old and when i changed the cartrige it started slamming the ink thing back and forth!! help
If you are using Windows XP try entering Printer and Faxes from your start menu.
Check your printer is indicated as ready rather than offline. If offline - reinstall the drivers.
If it is ready you have -print a test page - option. If the test page does not print then the conection cables may need checking.
If it is an ink problem then the paper will move through the printer, but nothing will be printed.
This may also flag up error messages which may tell you what is wrong.
Hope this helps.
What should we be concerned with concerning any glitches associated with the SAMSUNG CLP-315 Colour...
(More)
What should we be concerned with concerning any glitches associated with the SAMSUNG CLP-315 Colour Laser Printer we wish to buy
Thanks!
I have a HP Laserjet Colour Printer/Scanner/Copier (CM1017) that just decided one day to stop...
(More)
I have a HP Laserjet Colour Printer/Scanner/Copier (CM1017) that just decided one day to stop scanning. I have uninstalled and re-installed the software but still no joy. Any suggestions? Kathy
Help: Ik heb een HP-printer F2420 gekocht, maar krijg bij het installeren steeds de onderstaande...
(More)
Help: Ik heb een HP-printer F2420 gekocht, maar krijg bij het installeren steeds de onderstaande melding. module C:windows\system32\hpbmiapi.dll failed to register Ik werk met windows XP Vriendelijke groet, Jaap van Willigen
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
