Health-O-Meter Digital 2 Piece Platform Scale by Health O Meter Logo
D
Dana Buresova Posted on Nov 16, 2013
Scale shows error all the time - Health-O-Meter Digital 2 Piece Platform Scale by Health O Meter
My A12E scale is showing error 3 after which will come up with values even when there is no load on the scale
All question need FULL 'make model (what it is)'. You seem to be lots of details short.
If needs resetting or recalibrating. Try removing the battery for 30 minutes.
https://www.google.com/search?q=A12E+scale+is+showing+error+3
1helpful
My seca 813 only showing STEP OFF AND STOP massage cannot reset ??
If your Seca 813 is only showing the "STEP OFF" and "STOP" messages and is not responding to any commands, it is possible that there is a problem with the scale's sensors or the internal circuitry. Here are some steps you can take to troubleshoot the issue:
  1. Make sure that the scale is on a flat and stable surface. If the scale is on an uneven surface or is wobbling, it may not be able to take accurate readings and could display error messages.
  2. Check the scale's batteries. If the batteries are low, this could cause the scale to malfunction. Replace the batteries with fresh ones and try turning the scale on again.
  3. Reset the scale. Some scales have a reset button or function that can be used to clear any errors or malfunctions. Refer to the user manual for instructions on how to reset your specific model of scale.
  4. Check the scale's sensors. Over time, the sensors on a scale can become dirty or worn, which can affect their accuracy. Clean the sensors with a soft cloth or brush and see if this resolves the issue.
  5. If none of the above steps work, you may need to contact Seca support or a professional technician for further assistance. They may be able to diagnose the issue and recommend a repair or replacement if necessary.
My scale says err2 I have done everything
I got an ERR2 message and now the scale doesn't work. What should I do?
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero's or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call the manufacturer's Customer Service
38helpful
8answers
My Soehnle scale shows an out2 error - how do I fix?
How to calibrate when "out2" is shown.
With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
21helpful
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
5helpful
Nothing will display on the read out
15helpful
2answers
How to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
2answers
Scale does not work anymore. Batteries are still good
and same again. batteries are fine but i get an error message
pete scarborough qld
18helpful
4answers
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Top Health-O-Meter Health & Beauty Experts
NOEL
NOEL
Paula Hamilton
winchester
winchester
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
