Question about Jensen's VM9312 Car DVD Player
Face flex ribbon cable bad
It always restart when you text or call... i dont know if its the flex cable is not align i think the flex cable is the ribbon? sorry for my bad english
my dear,
kindly contact a samsung office nearby,
explain the problem to their specialist and it would be solved..
the phone needs flashing, its not a flex problem
hope this helps
Mar 08, 2011 | Samsung SGH-U600 Cellular Phone
NO display on touchscreen when slide out the keyboard
Hello there,
The problem you are facing with your phone is as a result of a bad flex connector cable which is attached behind your screen.the flex carries the signal from the panel mechanism of the phone and interpretes it on the screen,since the flex cable is bad nothing whatsoever can be transmitted on the screen.
The solution is to take apart your phone ,starting from the screws behind the battery cover,
You will find a ribbon like cable which is attached directly behind the LCD screen of your phone,this is the flex connector cable that needs to be replaced in order to restore your phone back to a normal working condition.
Best of luck.
Aug 13, 2010 | Cell Phones
My samsung has a white screen but it wull come back often, but when i slide it up to text the white screen comes back, Help.
This is a very common problem associated with samsung slide phones.
You will find a ribbon like cable which is attached directly behind the LCD screen of your samsung phone,this is the flex connector cable that needs to be replaced in order to restore your phone back to a normal working condition..
Take care.
Aug 12, 2010 | Cell Phones
When I open my laptop the screen becomes green and fuzzy. This is until I move the screen slowly backwards and eventually I hit a spot where it comes back to normal but if I move the screen forward or...
The ribbon cable to the lcd layer (green pixel contact common) is going bad or the connection of the cable to the lcd unit is dirty. It is probably the connection, as the ribbon cable, if installed correctly, will flex many more times than the hinges would be able to (that is, the ribbon cable should outlast the laptop). Sometimes they might not be installed correctly in that there is a hangup or kink of some kind and the bending (each time the laptop is opened and closed) makes it bend beyond the elastic limit of the metal, and it eventually cracks. The problem you have may be cause by the cracked metal in the ribbon cable, and careful placement of the screen makes the cracked trace reconnect by flexing. It could be caused by a bad contact of the cable to the board or (most likely) the screen unit.
If you are inclined, take apart and carefully inspect the ribbon cable for any parts that have a kink in it or is otherwise flexed too much in one small little area. Flex the cable to see if it changes the display. Otherwise, wiggle the ends (careful) to see if it will try to work.
If you find a cracked cable, have it replaced. If the contacts prove to be dirty, unplug or otherwise remove cable end that is dirty and reseat cable after carefully burnishing contacts and using contact grease (smathering only).
Nov 23, 2009 | Computers & Internet
Pioneer 7800MP can't turn on
It looks like the flexible cable worn out. Try to replace the cable.
This link may help:
Intermittent display on Pioneer DEH-P7800MP car audio
Mar 24, 2009 | Pioneer DEH-P7800MP
Face wont open
if you have already tried hitting the reset button you should first remove the faceplate and check the contacts on the main unit and the back of the faceplate. if they are dirty clean them (with power off) with contact cleaner or a small eraser. if your lucky that will fix the problem but most likely you have a bad ribbon cable. this cable attaches the faceplate contacts to the main unit and flexes as the face tilts. after time these cables get small cracks that may not be visible. you can usualy buy the part from a place like pacparts.com and replace it to solve your problem.
Dec 16, 2008 | Kenwood KDC-MP528 CD Player
Face plate on KDC-MP528 kenwood deck wont open
if you have checked all of your wiring and fuses and already tried hitting the reset button you should first remove the faceplate and check the contacts on the main unit and the back of the faceplate. if they are dirty clean them (with power off) with contact cleaner or a small eraser. if your lucky that will fix the problem but most likely you have a bad ribbon cable. this cable attaches the faceplate contacts to the main unit and flexes as the face tilts. after time these cables get small cracks that may not be visible. you can usualy buy the part from a place like pacparts.com and replace it to solve your problem.
3230 help.,
The flex cable is the weak link in all Flip style phons, so yes replace the ribbon/flex cable and most likely it will cure the problem.
Oct 28, 2008 | Nokia 3230
Replacing the facepale
that hole on that model is for a locking screw, the locking screw is installed to minimize theft and for other precautions. If the face plate is having any odd reactions its normally do to the flex cable. The best sign for a dying or dead flex cable is at the joint. The joint can be viewed at the point when you remove the face plate. Immediately after pulling the face plate off look behind the pivoting frame at the orange colored ribbon, you should only be able to see a small portion of it. If there is any sign of a yellowy residue its a sign that the protective covering of the ribbon is deteriorating. A bad flex cable is everything on the moving face plates.
Sep 06, 2008 | Kenwood KDC-716S CD Player
Kenwood MP925 cant get to work
The ribbon cable to the face plate needs replaced. It's an easy fix and any shop that does car audio repairs will likely have them in stock (mine does). Every shop has their own rates but my shop charges around $65-75 to fix that problem. Call around and ask. The bad part is: J84-0153-05 FLEX-RIBBON CABLE FROM FACE TO MAIN PCB
Sep 21, 2007 | Kenwood Sirius KDC-MP925 CD Player
Jensen's VM9312 Car DVD Player Logo
59 people viewed this question
Top Jensen's Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
