Related Tags:
This problem should be removed because:
Problem with Apple Mac/iMac&iPod Speakers-(Bondie-Blue) W/ Free CD/DVD Caddy-Limited Supply (p/n I-SPKR-BONDI) Computer Speakers
MacBook Sound Driver Issues
I've owned my MacBook for about 3 months now, and about a month ago, my internal speakers stopped working. I know there is sound, due to the 'ta-da' noise sounded upon turning the laptop on. When checking my 'sound' output option, it tells me it is set to 'Digital Out' with the 'Built-in Output' port. There are no other options to click on. I have been told this is the problem. When I use headphones or external speakers, sound works fine. Interesting point....about 2 weeks back, my friend was able to make it play via internal speakers by tilting the computer side to side, but it cut in and out. Is there a driver I can install to re-set my speakers to what they need to be? Thanks
Solutions (24)
Best Solution
Omigod, that worked!!!!
I was laughing at the idea of the match when i first read it. I have the same problem even with my Mac Pro. But to my suprise, the toothpick thing worked!I was flabbergasted!!!..So this means, a lot of Macbook owners experience the same problem?Is this some kind of a bug?
I was laughing at the idea of the match when I first read it. I thought the one who bought it up and the others who buy it are conspirators. But to my surprise, it worked for me!!!So, is this digital-out some sort of a Mac Book bug?Because the same thing also happens to my Mac Pro.
My macbook- doesn't give out sound thru external speakers and no sound in headphones . I bearly hear the internal speakers either so I took it to Apple Genius (with appointment) and they tested my macbook with their software fr.Macbook Pro using ethernet cord and start playing music and my macbook speakers- internal and external are loud again. WOW! So it's the infested 3rd party software such as Limewire and all others that we love to downloaded (but there are too many to figure it out which one is bad)...SO I backed up my stuffs and reinstalled macos X tiger and all is new again....WORKING PERFECT NOW!!! RE-INSTALL!!!! Thanks Apple Store!!!!!!
theres a easy solution, but its wierd.....TRUST ME......put a non metalic item into the audio out jack (tooth pick, match whatever) and gently press down (i just put a match in and turned it around while the sound properties was open) this will switch it between the digital and analog output......IT WORKS just make sure u have the sound properties up so u can see the output update
WOW! I think I love you Guest!!
I'm in spain - have had my mac for just over year - and constant problems - and when the sound just dissapeared - only digigal available - I took it to the store and they knew nothing -even though its stil in gurantee - they could have figured something for 79 euros (a lot more in dollars ) - OR the option was - they told me to re-install the disks that came with the mac to avoid having to send it away 3 weeks again - nightmare. I work with sound -so it's kind of important to be able to have it on my mac anywhere I go. So I tried re-installing everything - This only got all of my information erased and having to re-install programs, etc. - again - nightmare!
Not ready to be out with my mac for three weeks AGAIN - I came over here to this page - skeptical about sticking anything in any hole in my mac - but - thought "this thing is already f-d up ¿what have I to loose? If I've gotta send it away anyway?¿? - so here in the cafe - 5 minutes ago - I stuck my bic pen cap in - and VOILA!!! - Who'da thunk it!!! THANK YOU, THANK YOU THANK YOU!!!
Had macs like, FOREVER, since before we called them 'macs', and this had *never* happened before. WEIRD. But the matchstick thing worked. Just push it in and reset the headphones jack. You can tell that's what it is, because the jack is lit up inside. Just gently push straight in until it resets, and voilá! THANK YOU SO MUCH!!!
A GREAT MANY THAAAAAAAAANKS ........BLESSSSS YOU IT WORKS!!!!!!!1
Hi there!
This sounds like quite an odd issue, and based on the fact that you got the speakers to work by tilting the machine back and forth (with cutting in & out), this sounds like something might be a bit loose inside the computer, and will probably require a hardware fix.
You are still well within your 1 year warranty, even if you did not purchase AppleCare, so I would take the laptop to your local Apple store (www.apple.com/retail) Genius Bar. Make a reservation on-line before you go to avoid having to wait around.
I would highly recommend backing up all of your data before taking it in, just in case they need to ship it off for a repair.
there is no sound device no audio
My problem is solved .. i had download Bootcamp and install it ... everything is run normal .
you can get bootcamp on torrentz site for vista 32 .
Thanks anywhere !!
same here. instead keep something (like a toothpick) in there and then when u take it out, it should work again.
WOW this works the thing with a tooth pick i almost lost it this laptop was driving me insane now its working
i have a white apple macbook, i have downloaded vista on it, but the sound does not come out. please help me with this problem.
I pulled the cotton off a q-tip and it worked perfect, nice fix!
I just spent 30 min. poking the f-ing hole with a toothpick and it;s still not working and theres still that annoying red light
urgghhhh
how come its not working?
To those who are still having the erroneous red light... the problem could be (if you are Boot Camp users) that a bug in the Boot Camp 3.0 drivers left the audio output LED on when it wasn't being used. Updating to 3.1 should fix the problem.
To update to Boot Camp 3.1:
1. Boot to your Windows OS
2. Download the Boot Camp 3.1 update:
- 32-Bit Here: http://support.apple.com/kb/DL996
- 64-Bit Here: http://support.apple.com/kb/DL979
3. Insert your (Mac) OS disc and launch the update exe file
worked for me. that's funny. sooo lo fi
did nt worked for me :(((( please help me to resolve this issue, listen guys, it says tht no input device found.
how do i get it worked n pls help me to get drivers or wat.
regards
Thanks man! It really works with the match! Turn the match like a screwdriver - don't press down - and it will work! Cheers!
I also had the same problem, did it with the match, it worked in 10 seconds!!!!!! thx
I too used the end of a q tip, pressing DOWN is the key! thanks!!!
Same update, same problem, same red light. F!
i used my headphones to do the job.... NOTHING! bleg, saw myself going to applestore and leave it there for a week or so.... BUT restarted and then it all worked again. So: headphones AND restart
sound flickers from audio output to digital out
OMG THANK YOU SO MUCH!!!!!!!
I tried several times no work then I got a Q~tip cut OFF the end put it in and left it for several minutes. Do not know why it worked but it did Thanks who ever discovered this.
so I have the same problem only I have a black Macbook and I def. CANNOT find this black gadget you guys speak of..where is it? I have been trying to figure this out for the past month or so..
I know that supposedly it's supposed to be on the right side of the port, but I DO NOT see it anywhere..
&& I have used a hairpin, a q-tip, and anything else small I can think of. The only thing I haven't tried is a toothpick because I don't have any..
HELP!!
That toothpick idea is brilliant!! how did anyone come up with that idea
It worked for me!!!!!! Like the post above, you have to turn it around the edges like a screwdriver. Thank you so much!
Suggested Solution (1)
Sounds like the cutout switch in the output jack is stuck open, it is a techy fix sorry (at least it is not a board failure)
Source: MacBook Sound Driver Issues
I've owned my MacBook for about 3 months now, and about a month ago, my internal speakers stopped working. I know there is sound, due...
No sound at all
My Macbook started making a clicking noise internally, then stopped and now doesnt make any sound. The only option I have for output is my...
sound not working on my macbook
The sound is not working on my macbook - Only "built-in output " is showing under Sound in Output option.
how do I get them to work with a MacBook Pro
how do I get them to work with a MacBook Pro snowleopard OS
Add Your Solution
i am trying to find a good free fps app for ipod4g...
please help me.
can i buy music for my ipod from amazon
i would like to buy some music from amazon and put ot onto my ipod wat is the procedure thankyou
single white line about 3
i tried shutting and re-booting. nothing changed.
cant transfer tunes to phone
cant transferfrom laptop to phone i tunes works fine until i plug phone in then a exclamation mark comes up in i tunes...
See all Apple Mac/iMac&iPod Speakers-(Bondie-Blue) W/ Free Problems
Fix-O-Meter
49,270
49,270 people viewed this problem
- 39 people found this problem to be helpful.
- 1 person is following this problem
Top Apple Computer Speaker Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
