James, I used to have one, but I spent so much time fighting it that I gave up and sold it. I would go online and check out sleep apnea mouthpieces (that typically treat snoring, but work for apnea as well!) They work pretty well, are much less expensive and much quieter, and much less invasive!!!! Good luck!!
Just so you know there is a recall on this and may end up with a new one... read below
Respironics, the manufacturer of the Respironics REMstar Heated Humidifier, has received complaints of failures of the AC inlet connector on the REMstar Heated Humidifiers manufactured between December 2001 and April 2003. A small number of these failures have resulted in thermal damage to the humidifier enclosure, and there is a remote possibility that a thermal failure could result in the ignition of materials external to the device. For this reason, Respironics is asking that you remove the humidifier from its power source. You may continue using your CPAP device.
Respironics has decided to take voluntary action to mitigate the risk of failure. This action includes only the model 1005792, U1005792, R1005792, SC1005792, AC1005792, and 1007861.
This voluntary action is classified as a medical device recall, and is being conducted with the knowledge of the United States Food and Drug Administration (FDA).
WHAT TO DO:
Call Stericycle, Inc at 877-574-5038 or 317-275-7667.
reset the humidifer, Turn off, wait for 3 minutes, and try again. If the problem persist, see your owner manual go to the website from the supplier and get support via ONLINE chat for fix it. God bless you
