D-Link AirPlus DI-524 Wireless Router
Problem for D-Link AirPlus DI-524 Wireless Router
Cant connect
By purplegarion on Oct 07, 2007
i have bought a d link router model number d1 524 i have put the disc in followed the instructions all lights on the router are on everything is fine untill it goes to load on the computer as soon as i plug the router in to my modem i loose connection to the internet so it wont load i get a message saying error enter password . can some one A tell me what password and B what i do.aaaaa
Same Problem
Jan 12, 2009
-   Same thing-   Guest
Solution #1
posted on Oct 11, 2007
Not Rated)
Cerfer39
Rank: Guru
Rating: 87%, 1165 votes
Hi purplegarion,
hook up the router per instruction in manual and your particular internet connection.  With the Di524 powered up, use the end of a paperclip to depress the reset button located in a little hole beside the power connection.   open internet explorer and type in 192.168.0.1 and press enter.  The password is admin. once th screen appears, click on Wizard.  Follow the wizards directions carefully.
For simplicity of security click on the wireless button while in the  wireless screen.  Set radio to on.  Enter a SSID like purplegarion. Set to open system.  Set Security to WEP.  Wep to HEX.  64bit.  Enter into Key one a 10 digit number you can remember like 1234567890.  Click apply.  Change your password to a personal password other than ADMIN.
Any device that attaches will need to enter the WEP 64 Bit hex Security key 1234567890, or whatever 10 digit number you put in the router.
Internet connection will require powering down you modem, and the DI-524 router.  power up the modem first and let it go through the start up, then power up thte DI 524.  you may need to make sure your DHCP is set to Automatically assign an IP address.
Was this helpful?
Yes
No
Popular Solutions for D-Link AirPlus DI-524 Wireless
Questions and Unsolved Problems for D-Link AirPlus DI-524 Wireless
Do you recommend D-Link AirPlus DI-524 Wireless Router?
Answer
Answer
DL 524 signal intermittent! The wireless connection drops when more than 1 user is trying to use the... (More)
Answer
my d-link router wont allow me to connect wireless to ps3
Answer
when i go through router setup it locks out my laptop. i need securitybut my own access at same... (More)
Answer
After reseting my DI-524, accessing it yields screen telling me to update the firmware. I've tried... (More)
Answer
beste ik heb een probleem met mijn laptop kan niet meer op internet via mijn router hij en ik ben de... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Routers Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
