SOURCE: 2004 Kia Sedona trying to find the starter.
it is located on the drivers side underneath the van. you have to remove it from the underside of the car. you will need a 17 millimeter socket or wrench. Remove the ground cable before attempting to remove the starter.
SOURCE: 3 lights on my sephia kia on at the same time
Sounds like some of your internal wiring might be burning up. Check your Fuses too,
You can't drive around like this too long; take it to a garage to get it repaired now rather then later.
I hope this helps,
Thanks.
SOURCE: 2005 kia Sedona
It's normal for belts to loosen up a little after installation. I'd check the belt and re-tighten until there's no slack. A slipping belt would certainly cause the issue you have. Hope this answers your question. Best of luck!
Greg
SOURCE: 2004 kia optima. After a 5 minute stop at a store,
have check to see if your maf sensor might be dirty this sensor is located in the air intake it has two screws that hold it in place (make sure you scratch a little indentation to see which way it went )take it off wash it in alcohol scrub in the little window that holds the element with a cutip not to hard then let it dry off and put it back on your car this will help you for a while them you will have to eiter do it again or buy a new one
SOURCE: my 2004 kia sedona shut off while driving it made
Tranny problems. It could have seized up and thats why it won't start.
