Question about Seagate U5 (ST320413A) 20 GB Hard Drive
Physical damage Hi, I have a 20 GB U5 ST320413A Seagate HD.One of the pins is physically teared and I try to replace it by a hook up wire. At first, I successfully accessed to OS and desktop. But after a while it will boot up again and "Primary Master drive fails" is displayed, this routine continous over and over. I decided to solder again the wire but unfortunately the soldering lead spilled to the other pins. Is it possible to replace the logic drive circuit ( the circuit at the top of the metal platers) with another one? Is there any available at the market?
  • budz Oct 08, 2007
    Thank you, that will help a lot! What about if I replaced the Logic drive controller with another one from same model type, is it compatible?
  • 661 Answers
If you have spilled solder in this way you can use some solder wick to soak up the errant solder, solder wick, is a braided copper string designed to collect melted solder, simply apply the solder wick to the aggregated solder and melt, the wick will soak up the solder, you can then cut off the saturated section of wick and continue to soak up the spilled solder, then just refresh any solder points you have removed the solder from.
Posted on Oct 08, 2007
  • Gareth Cockram
    Gareth Cockram Oct 08, 2007
    you can get solder wick from any good component store
  • Gareth Cockram
    not sure.. I have done this myself but only with identical drives,
    if the card is not compatible though there is nothing stopping you from taking a pin from the IDE connector and replacing the one that broke. (desolder first and remove with needle nose pliers)
Hi, I have a Seagate ST38421A HDD in an EMachines EOne PC, very old, Win98. When I turn on the PC it says there is no HD found in the system, and when I try to install Windows XP, it says it has no...
Sorry to say it it but your hard drive in your computer has stopes working. Best way to fix it is to buy a new hard drive for your computer or just buy a brand new computers.
Mar 04, 2011 | Seagate U4 8421 (ST38421A) Hard Drive
Error 01-0134-0000?? It says the tool could not get HDD physical information? Is my hard drive fried? Or what else could it be? How do I fix it?
I suggest you download a free HD test and check the HD. I like to use Seagate's SeaTools, which work for ANY brand of HD. Go to the Seagate website here:
http://www.seagate.com/www/en-us/support/downloads/seatools
and download "SeaTools for DOS", Be sure to get the "v1.10 (Text) English", the ona under the "ISO CD-ROM Image" column. This will download an ISO CD image that you need to burn onto a CD. This will create a bootable CD that you use to boot your computer from (no OS needed). Then, run the HD tests for as long as needed (it may take a couple of hours to run, depending on your HD's capacity). SeaTools will diagnoze your HD and tell you if there is an irrecoverable hardware error.
Mar 28, 2010 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Hard drive will not open files. when I try F:\ is not accessible
This problem either means the HD enclosure is damaged or the HD itself is damaged.
Try taking it to a local computer shop and ask the techs to swap the HD into a new enclosure(will void the seagate warranty), they can then test the drive. If it works you're off and rocking, if not the drive is damaged and you will require the help of a pro to recover your files.
That being said, if you don't have any files of value on the drive and it is under warranty, just contact seagate for a replacement. They'll be happy to replace it.
Chris
Jul 12, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
HD will not spool up on Windows XP
Try running the Seagate SeaTools software and see if there is a physical problem with the drive.When you install it, run the SMART test and the short drive self-test ONLYhttp://www.seagate.com/www/en-us/support/downloads/seatools/
Jun 13, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Data Recovery from Seadate ATA 10GB Hard Drive
Depends on the noise it is making. If it isnt getting enough power to the drive, your best bet is to find another drive on Kijiji or eBay that is the exact same, and then relace the Printed Circuit Board on the bottom.
If this fails, the only real option is to go to professional driver recovery, which is upwards of 1000 dollars.
If the drive still shows up in Windows, there are tools you can get to repair the drive, but your problem sounds physical
May 01, 2009 | Seagate U5 (ST310211A) 10 GB Hard Drive
I have a Seagate 60 Gb drive which I have connected to two machines running xppro sp3. On each machine it shows as 31Gb. I go into DiskManagaement and delete the only partition (no unallotted space) and go...
surely this is a firmware problem that seagate usually has,sometimes the drive cannot be detcted by the pc or even bios,and sometimes the drive detcted by the pc as 0GB or less capacity,you should find a tool such as HD Doctor for Seagate to repair it.Or you can go 2 a DR company to rewrite the firmware.
Apr 25, 2009 | Compaq (166361-001) Motherboard
I got a system form my school with no HDD. I got a standard IDE interface seagate baracuda 7200 rpm 160 GB HDD. I tried booting the system with a boot CD. But the error it is showing is CDBOOT: Memory...
If you have both a CD drive & a DVD drive, make sure you are using the 1st physical device (according to physical hookup).
Or if you do have both, then try booting with CD in other drive
Dec 27, 2008 | Computers & Internet
Problem of physical memory dump
physical memory dump occurs when more than 1 program try to occupy same space in RAM.
Actually there are many products available in the market for this.
i just recommend you to download and install trial version of IOLO SYSTEM MECHANIC and run it on your pc.
this will solve your problem
Sep 13, 2008 | Seagate FreeAgent Go 80 GB USB 2.0 Hard...
Shorted 12V on input to drive
Basically 2 options I think.
1. If you feel comfortable working with electronics, familiar with a DVM (looks like) and a soldering iron, it possible to check the electronic board of the HD. You need to do component level check of that PCB. Some of these old HDs have a reverse protection diode installed right after the power connector. At times it could be the surface mounted capacitor. The worst is the servo drive that powers the motor. Normally, the 12V in an HD is for use of the motor while the 5V is for the logic circuitry.
2. If you need to replace the HD, just about any hard drive should work for your PIII (just not the new big ones). Sources would be your neighborhood computer repair shops or a neighbor/friend who's got a defective PC and would probably just throw them away rather than have them repaired. You can salvaged the parts and hopefully a working HD. Most also would already have Win98SE and transition from one system to another in 98 would not be that much of a hassle. You can then use your original Windows key.
3. Should you get one that has no OS, you can use an OEM Windows installer and still use you original CD key.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Dec 24, 2007 | Seagate U5 (ST320413A) 20 GB Hard Drive
32 GB hard drive limitation
WinXP & Win2k cannot create FAT32 partitions larger than 32 GB.IF you want to use partitions larger than 32GB in WinXp then you will need to install a third party partition tool like Partition magic. Partition magic is probably the best coz i have formatted my 200GB HDD in 2 mins flat!
Oct 08, 2007 | Seagate U5 (ST320413A) 20 GB Hard Drive
Seagate U5 (ST320413A) 20 GB Hard Drive Logo
78 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
