Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Candy washing machine fills with water whe...
By ctmd on Oct 07, 2007
The washing machine seems to work no problem, washes, spins and empties. Yet when left for a while, I come back to open the door and it is at least half full of water. It did this once before, while still under warrenty, but stopped doing it just as I gave up trying to work out why and was about to call in an engineer.
Can you help with ideas?
Same Problem
Sep 02, 2008
-   I have the same problem. My washer keeps filling with water between loads. It's a big problem if I don't empty my washer as soon as the load is done as I have to re-spin the laundry.-   nmiklaucic
Apr 06, 2008
-   My washing machine fills up with water when not in use. It washes, drains, & spins, but then fill up again. I have taken the machine apart and cleaned everything and have no blockages or flow problems. I push drain/spin and then I am able to do a load of laundry.-   teamthompson
Mar 13, 2008
-   SAME PROBLEM washing machine fill with water when not in use<only cold water supply to this machine and seems to fill from the bottom and not through the soap tray<havent dismantled yet to check > james-   cowsarse
Feb 10, 2008
-   I have the same problem. The drum is filling up while the machine is switched off. I think the hot water inlet is trickling water through the soap tray even when it is not on. Can I replace the inlet valve without calling an engineer?-   Mocky
Best Solution
posted on Oct 07, 2007
Very Helpful)
premm
Rank: Guru
Rating: 93%, 3340 votes
Do check your outlet filter, this requires periodic cleaning according to your usage. Refer to your user manual re cleaning filter.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
whirlpool ultimate care ii washer LSQ9110PW2
Answer
I have a Kenmore washer. My clothes come out smelling like wet dog. What can I use to clense... (More)
Describe your Washing Machines problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Newport, KY
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
