Question about Acer AL1717 17" LCD Monitor
MONITOR DIPLAY PROBLEM - Acer AL1717 17" LCD Monitor
Computer starts but no diplay shuts down immediate,
Is the power LED on the monitor ON, if not check the power cable connection at the monitor and at the mains.
Check the video cable connection at the PC.
Try a different working monitor on your PC and see if the monitor works on a different PC (the monitor maybe faulty).
Nov 17, 2012 | E-Machines T Computers & Internet
I've got a Philips 221V mnitor and it diplays:
boot your pc , keep on pressing f8 key then select safe mode option, remove the graphic driver, then shut it down, then again start install the graphic driver
Jul 28, 2011 | Philips C.927126 Monitor
My dell monitor model #1800fp diplay is elongated for all pictures I display on the screen. How do I correct this
should be on the menu on front of monitor ,,with options to change that,,and check control panel on cpu,,make sure its set rght,,for widescreen or regular
Nov 03, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
E151FPp (Gray) 15 in. Flat Panel LCD Monitor: I am not able to get DIplay Driver for my LCD moni...
The 32bit color has nothing to do with monitor driver, that the video card driver issue, it sounds like you do not have correct driver for you video card.
http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | Dell E151FPp 15" Flat Panel LCD Monitor
Hello. This computer will recognize a good
This is the problem with the display capacitor on your motherboard. Try replacing the display capacitor by good technician. If it doesnt solve your problem you need to change the motherboard. But mostly this will solve your problem.
Oct 15, 2009 | HP (D9820-60007) Motherboard
My lcd model # 1901FP when power on dispaly on after 2sec diplay off at this time power led show green .again power on /off button off and on the same (power on dispaly on after 2sec diplay off at this...
Hi, This is a common problem with LCD monitors and is usually a result of blown capacitors or it could be a failed backlight as the inverter will shut down if it detects this. You will need to open up your monitor and you will be able to see if any capacitors have "blown" but failure of a lot of components will cause this symptom.
Oct 14, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
My compaq sr181nx diplay monitor is now blurry
This could be a faulty monitor. Trying plugging in a different monitor to the computer.. If you continue to have the same problem with the second monitor, then it is your video card or on board video that is going out. If the video is fine after you tried the second monitor, then you need to get a different monitor for your system.
Jun 14, 2009 | HP Compaq Presario SR1810NX PC Desktop
Half Display
That Seems to be a panel problem.Benq provides 3 year warranty,Try contacting local BenQ service centre in your country.
Samir
Aug 11, 2008 | BenQ FP71E 17" LCD Monitor
Acer AL1717 17" LCD Monitor Logo
35 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
