Question about Toshiba TP71G90 71" Rear Projection Television
Toshiba convergence problem
I have a toshiba TP71G90, I have a convergence problem. I allready changed the two stk's with original replacements and I still have the problem, It is a little better than what it was before but I can't adjust the convergence in the service mode. It does let me in the service mode but when I try to adjust the convergence by going to built in cross-hatch pattern but it will not show it, also if I try to go to the main menu to select the convergence mode there is no cross displayed. Can someone please help any ideas. I also changed the resistors in front of the stk's.
  • 375 Answers
Digital convergence or eproms
Posted on Oct 07, 2007
Toshiba 65hdx82 convergence issues
check fuse resistors near STK, and broken PCB around digital convergence board (board in a metal box verticaly mount beside STK.
Apr 23, 2010 | Toshiba 65HDX82 65" Rear Projection...
Toshiba TP48C90 Convergence (replaced ICs, worked for 2 days)
Well, my thought is that there are a ton of knock off generic convergence IC's out there that usually hold up as long as yours did. Professionals like me will only use Sanyo original STK's. The counterfeit STK's out there are everywhere. Do some research on the web to locate Sanyo originals, they are out there.
Jun 11, 2009 | Toshiba Televison & Video
The problem is probably that one or both of the STK convergence chips have failed. These control the convergence coils around the red blue and green guns and are the most common cause of sudden convergence problems and the protection circuit shutting the TV down when turned on.
I can post details of how I replaced these on my Toshiba 40WH08B. Yours should be similar.
Mar 02, 2009 | Toshiba TP55F80/81 55" Rear Projection...
STK IC CHIP 392-110
I made the same repair in a Toshiba 42h81 I replaced the STK 392-110 and after a lot of searching found the cheaper ones last 6 month or so be sure to use Sanyo IC's and replace the resistors with them when the IC's let go they take the resistors out I posted my repair On my page if it will help you
Dec 02, 2008 | Toshiba 42H81 42" Rear Projection...
STK IC 392-110 Chips
am having stk 4392 amp board 2 channel, i want to change this two channel in to one channel. what modofication should i do
Toshiba 42h82 convergence resistor and pico locations
(6) 1.8 ohm 1watt metal film resistors for R7711, R7716, R7721, R7726, R7731 and R7736 yes the STK 392-150 will work fine.
Sep 24, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba tw40f80, replaced both convergence ic's, power light still blinks
Solder yoke plug and vertical IC connections.....try again.
Let me know.....T.
BTW....Tosh recommends STK-392-110's replace with -110T's
Toshiba OEM.....then there is no question about resistor value
Aug 03, 2008 | Toshiba TW40F80 40" Rear Projection...
Toshiba tv convergence problem
did you change the resisters the same time as the ic? some have reported that they got generic IC (cheaper) and have failed.
Oct 06, 2007 | Toshiba TP71G90 71" Rear Projection...
Toshiba television convergence problem.
ok if you already replace the convergence amp, you can check all small parts like resistors or capacitors maybe you have change value parts at the convergence section!
Televison & Video Logo
61 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
