Unlocking problem in my tab3 when i press power button to unlock pattren appears but touch doen't work and again i have to press power button again and unlock pttrn apperars then it opens in short my tablet is not unlcok in first attmpt
To unlock the bootloader on your Lenovo Tab3 7 Essential (TB3-710I) tablet, you need to follow these steps:
Note: Unlocking the bootloader will erase all data on your device. Make sure to backup your important data before proceeding.
Enable Developer Options on your device. To do this, go to Settings > About tablet > tap the Build number 7 times.
Enable USB Debugging. To do this, go to Settings > Developer options > enable USB debugging.
Download and install the ADB and Fastboot tools on your computer.
Connect your tablet to your computer using a USB cable.
Open a command prompt window on your computer.
In the command prompt window, type the following command and press Enter: adb reboot bootloader, This will reboot your tablet into the bootloader mode.
Next, type the following command and press Enter: fastboot oem unlock, This will unlock the bootloader on your tablet.
Once the process is complete, reboot your tablet by typing the following command and pressing Enter: fastboot reboot. That's it! Your Lenovo Tab3 7 Essential tablet's bootloader is now unlocked.
https://support.apple.com > en-gb
9 Dec 2015 - Press and hold the Sleep/Wake button until the red slider appears. Drag the slider to turn your device completely off. After the device turns off, press and hold the Sleep/Wake button again until you see the Apple logo.
Try restarting it: hold power button down until "slide to power off", power off for 10 seconds, press power to restart.
if that doesn't fix it, reset your iPad: hold BOTH power button and Home button until device resets and apple logo appears.
Touch
the "Power" or "Unlock" button (depending on device) to
unlock your device screen.
Press the "Power" button to turn the device off.
Press the "Power" button to turn your device
back on.
2.Factory Reset
o4
Touch Menu, then touch Settings.
o5
Touch Privacy or Storage, depending on your device.
o6
Touch "Factory Data Reset." A warning message
appears. Touch "Reset" to confirm your choice and reset your device.
This works with devices having physical home button:- 1. Press the power button and the home button together
for a while, long enough until the screen appears with Android bot and a
progress bar which shows that it's formatting the internal memory. With NO physical HOME button:- 2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds. 3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
Try to visit my blog to see video tutorial http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
This is the "master" reset procedure. No other way of clearing the unlock pattern. *******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. . Step 9- Press the Menu" button to select "Yes- delete all user data". Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Here is a step-by-step procedure on how-to perform a factory reset when the unlock pattern code has been forgotten:
This is the "master" reset procedure. No other way of clearing the unlock pattern. *******This procedure will delete all items (file's) and entries on the MID7015******
Step 8- The following screen will appear. . Step 9- Press the Menu" button to select "Yes- delete all user data". Step 10-Press the "reset" button.
