Question about Kurzweil Computers & Internet
Start up problem
When I start up my Kurzweil K2000 VP, it just shows a blank screen. The screen is illuminated but there is nothing displayed there. I plugged a speaker into the main output and there is no sound coming either. What should I do about this?
SOURCE: Display shows only L and R speakers.
I think you need a digital coaxial wire instead of the composite ones
Posted on May 17, 2008
SOURCE: it turns on but a blank white screen only shows
i had the same issue when my phone got slightly wet. try taking everything apart (sim card, battery, back). let them dry out for a little bit then after like a day or two put the phone back together. turn it on it will be a white screen for a little bit but give it like 2 or 3 mins and if should come back. I did this for my phone cuz i really needed the pictures off it and it worked! hopefully if will work for you too. GOOD LUCK!
Posted on Jul 23, 2008
SOURCE: Audio output is quiet
http://www.dspdesignline.com/showArticle.jhtml?articleID=196900003
The above link has the detailed description of how a matlab code is converted into C language.Hope this solved your problem.Please do rate if the problem is solved.
Posted on Dec 05, 2008
  • 144 Answers
SOURCE: Is my sound card fried?
hmm ,,,r u not geting sound ,,well try download the sound drivers ,,you can download the sound drivers from this website sound drivers ---> http://www.softwarepatch.com/utilities/ac97.html and http://www.softwarepatch.com/utilities/ac97.html
Posted on Jan 14, 2009
  • 29 Answers
SOURCE: Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Posted on Aug 01, 2009
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
Apr 14, 2016 | Kurzweil Music
PC88MX powers on however nothing legible in display?
you must open it. and test if there are some cable or connector loose or corroded and use contacts cleaner, and try again.
God bless you
Nov 03, 2013 | Kurzweil Music Systems Kurzweil PC88MX
2006 Honda Accord Vp Stereo System went out and i have checked every fuse and nothing is working! It started out with the DISPLAY ILLUMINATOR now the whole STEREO went completely Is there any
time to rip it out and fit a after market one ,it sounds like microprocessor has packed up and its cheaper to replace than mess around trying to get it repaired
Apr 27, 2012 | Cars & Trucks
What's your problem?Need help to fix my kurzweil pc 88 ... no function just powers on but no display...need help urgent
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 01, 2012 | Computers & Internet
KURZWEIL K2000 Synthesizer/Keyboard My floppy drive gives the message "Problem Mounting Disk" when I try to read a floppy. The floppy is the Kurzweil K2000 Factory Programs and Demos, so it...
Hi
Remove the battery, and clean the compartment of any old corrosion on the contacts. Leave the batteries out for a few hours. Allow all static electricity to drain. While it's off and UNPLUGGED work the power switch a few times to bet all the charge in the capacitors of the power supply. Press some buttons.... let it rest a few hours. Next return the batteries and start the machine. Your problem appears to be corrupted boot up of the Operating and Setup chips after a partial discharge and rapid reboot.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 14, 2011 | Computers & Internet
Blank screen
Quite possible that the machine is defaulting to external display only. Check your BIOS for this and try any function keys/switches that are available.
Sep 10, 2008 | Gateway MX3414 Notebook
Nokia 6070 Service Manual
Check with nokia.com. They usually have them in pdf format.
You phone provider may have it on their website as well.
Jun 13, 2008 | Nokia 6070 Cellular Phone
PHASER 8500 XEROX
Is the display saying NOT READY, or is it not comming on.
If the display is blank there is a known problem with those displays and Xerox will replace them free of charge.
If you have a blank display, call 1-800-835-6100.
If I am misunderstanding the issue provide more details please.
Feb 29, 2008 | Xerox Phaser 8500N Printer
Computers & Internet Logo
104 people viewed this question
Top Kurzweil Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Kurzweil Computer and Internet Expert? Answer questions, earn points and help others
