Question about HP PSC 1410 All-In-One InkJet Printer
Incorrectly installed cartridge pop up
I have a Hp 1410 all in one printer Past few days i have not been able to print anything because, when ever i switch on the printer there is a pop up telling me that the black cartridge is not installed correctly. I have read someones solution to clean the cartridge but that does not help either. What can i do to solve this problem .
  • 2 more comments
  • Anonymous Nov 06, 2007
    My HP Officejet 6210 All-in-one printer/fax says "remove and check color cartridge". It won't perform any other function either (scan, print black only, fax). We don't use the color very often and I took it out and wiped off the dry color. Is there anything else I can try before I pay $25-35 and not guaranteed that this will work.
  • Anonymous Nov 27, 2007
    Incorrect Print Cartridge installed.
    Had not touched the cartridge.
    Red light flashing on Check Print Cartridge
    Have cleaned cartridge
    Checked with dealer - plenty of ink in cartridge - unsuccessful
  • Anonymous Mar 21, 2008
    would not print in black so I bought a refill kit and added ink still nothing. plus I bought a new color cartrige and the aliment page is all blue for my hp psc1410
  • susa_susa Mar 27, 2008
    have the same problem with my Hp psc 950 all -in-one, I bought a new cartridge, but non genuine, didn't solve the problem. No idea what caused this?? did I have to buy genuine cartridge or the problem is far away from this limit??? Any help?
    Thanks
Put tape on your electronic circuit at the left and right ....
Posted on Jun 08, 2008
Cartridge problem replace the cartridge
Posted on Oct 07, 2007
Buy a new printer. i have the same problem, over and over im sick of it!
Posted on Dec 08, 2007
SOURCE:
I don't have many more details. We put in a new cartridge a few weeks ago, but my wife said it was working okay for a couple days, and then after that it began taking an extremely long time to print.
Uninstall the printer. Goto Control Pannel - Printers and Faxes and delete the printer.
Re-install the printer. This would fix any issues with the drivers and setting.
Hope this helps
CreativeTECH
Nov 05, 2010 | HP PSC 1410 All-In-One InkJet Printer
HP printer PSC 1410 ALL in one printer showing "Check print cartridge" error
This eror usually mean that the printer cartridge has not been installed correctly. Try re-installing the cartridge. This error can also be generated by a logic fault within the printer.. if this is the case, replace the printer.. trying another new cartridge can be expensive so try and get a second hand cartridge, maybe from a friend and try that one.. Otherwise, replace the printer..
Oct 27, 2009 | HP PSC 1410 All-In-One InkJet Printer
HP PSC 1410 All-In-One InkJet Printerred ink problem
I know this might sound silly but there is pieces of plastic on the bottom of the cartridges that cover the holes to keep them from drying out, make sure they are removed and then reinstall the cartridges and see if that helps.
Feb 06, 2009 | HP PSC 1410 All-In-One InkJet Printer
Hp psc 1410 printer error message
I fixed the problem I was having by re-installing the program, which then told me exactly what the problem was. It was the color cartridge.
I then put a new cartridge in and it worked!
Jan 29, 2009 | HP PSC 1410 All-In-One InkJet Printer
My hp all in one 1410 printer prints in green
Initially it seems that your colour cartridges are about to be empty.
Refill or Install new cartridges and try taking printout.
Jan 26, 2009 | HP PSC 1410 All-In-One InkJet Printer
Printer reads "Incorrect Print Cardtridge Installed"
According to the HP website, the correct cartridge for the HP PSC950 is HP15 or HP78. Comes in black only or tri-color.
Dec 22, 2008 | HP PSC 950 All-In-One InkJet Printer
Check Printer Cartrige
my printer is
HP PSC 1410 ALL IN ONE PRINTER
ERROR MESSAGE
1. CHECK PRINT CARTRIDGES
I AM REMOVE THE OLD CARTRIDGES
THEN NEW ADDED 21,22 CARTRIDGES
THEN NEXT ERROR MESSAGE
HOW TO SOLVE THE PROBLEMS
Jul 09, 2008 | HP PSC 1410 All-In-One InkJet Printer
Hp psc 1410 all in one
If You have light or message about print cartridge or alignment problems
Cause: The incorrect type of paper is loaded in the paper tray.
  • Solution: The paper must be blank and white for the alignment to succeed.
    If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP
    Support by going to www.hp.com/support. Click Contact HP for information on calling for
    technical support.
Cause: Protective tape is covering the print cartridges.
  • Solution: Gently remove the plastic tape by using the pink pull tab. Do not touch the ink
    nozzles or the copper-colored contacts.
  • Reinsert the print cartridges and verify that they are fully inserted and locked in place.
Cause: The contacts on the print cartridge are not touching the contacts in the print carriage.
  • Solution: Remove and then reinsert the print cartridges. Verify that they are fully inserted and locked in place.
Cause: The print cartridge or sensor is defective.
  • Solution: Contact HP Support. Go to www.hp.com/support. Click Contact HP for information on calling for technical support.
(These help is from HP manual you can refer for details.)
Thanks
Iqbal
Apr 01, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP Deskjet 6980
Take a look to see if the printer Cartridge Carriage belt is hung up
or something else is jambed.
Sep 12, 2007 | HP PSC 2110 Color Printer
Hp psc 1410 all-in-one printer not printing
What is not working? The printer or the cartridge? If it's the cartridge, try this. fold a paper towel in 4ths, dampen it and place on a flat surface. Blot the cartridge several times on the towel. You should get blots of black with the black cart. and three colors with the color or photo cart. If not... replace. If the printer carriage just won't move and you're shure you have power.. time for a new printer.
Aug 27, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP PSC 1410 All-In-One InkJet Printer Logo
168 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
