Question about Dell E193FP 19" LCD Monitor
19"LCD DELL E193FPp ---If to direct a ray of light on the screen that it is possible to see the image.what the problem is,
  • 24 Answers
Hello.
Your problem in this particular instance is thet either the backlight bulbs have failed, or the inverters that power the backlight lamps have failed.
Good luck.
Posted on Oct 15, 2007
How to remove the front bezel from a dell e193fpp monitor by hand?
Seek a troubleshooting manual
http://r.search.yahoo.com/_ylt=A86.JyZM1D9XbXgAZOBEDN04;_ylu=X3oDMTByN2lydWw3BHNlYwNzcgRwb3MDOARjb2xvA2dxMQR2dGlkAw--/RV=2/RE=1463829708/RO=10/RU=http%3a%2f%2fservicerepairmanuals.net%2fcomputer-monitor%2fdell-e193fpc-lcd-monitor-service-manual%2f/RK=0/RS=CK8mHx7DCNfOWVMhlLjDV6MvmXw-
Aug 17, 2014 | Dell E193FP 19" Flat Panel LCD Monitor
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
How to control the brightness of Dell TFT monitor
That's the buttonsd on the monitor, not the PC.
Press the [menu] button on th emonitor.
The screen will show the labels of the buttons now.
press the "arrow" to position to the brightness setting (the "sun" icon)
press the minus [-] button to dim
Press [Menu] to save & exit the OSD (on screen Display)
Sep 30, 2009 | Dell E193FPp 19" TFT LCD Flat Panel...
Just plugged a Dell E193FP monitor into my emcahine - running XP - turned it on and video display said ''cannot display this video type''
The computer is not able to communicate with the hardware properly. It can be solved installing the Video drivers (The video card drivers AND the display drivers).
Check for updates with the manufacturer of the video driver.
To determine what Video card your computer has, just right click in MY PC - MANAGE - DEVICE MANAGER and click Video, check properties.
Good luck.
Mar 27, 2009 | Dell E193FPp 19" TFT LCD Flat Panel...
Monitor stand
I was reading a discussion about a replacement stand for your monitor here:
http://www.americanpoems.com/Reviews/ItemId/B000FLXW90/ReviewPage/9
I think the item in question is really ;
http://www.americanpoems.com/B000FLXW90/Neoflex_LCD_Stand_Black.php
Aug 16, 2008 | Dell E193FP 19" LCD Monitor
Dell Flat Screen Model 1907 FPt
Appears you have an inverter problem. Do you hear any sparking?
Mar 29, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell 19" Monitor - Dead
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it went blank, you have to check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like mine, I can see window image using flashlight and check lamps inside. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Mar 15, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell E193FP 19" LCD Monitor Logo
150 people viewed this question
Clive
Clive
Alun Cox
