Loud noise and smell
I would like to know what is wrong with my machine. It had just went on the rinse cycle and was proceeding to drain all the water out and all of a sudden I heard this loud noise . louder than the buzzer on the dryer and I started smelling something starting to burn, almost like rubber or something , coming from the back of the washer. It makes this noise as soon as I pull the switch to turn it on. If someone can tell me what is wrong, please contact me at my email address: kayerobinson1@yahoo.com.
  • pam55555 Oct 08, 2007
    IT IS A KENMORE 70 SERIES.
Thanks for the info. I had someone come and get the machine tonight. They looked at it and said the whole transmission was shot and the coupler was fine.
Posted on Oct 12, 2007
Kenmore 70 series washers are direct drive machines. The transmission is joined by a drive coupler.When this wears out the transmission cannot engage but the motor still spins causing friction on the broken rubber coupler which makes the foul smell shes describing.
  • 290 Answers
It would help to know the brand and model number of the washer. If it has a belt that also runs the pump, something may have gotten into the pump during drain and locked the pump causing the belt to slip.
Posted on Oct 07, 2007
I have an haier washing machine that gets stuck at the rinse cycle. What could it be? Plus it makes loud grinding noise.
are u saying its putting water in the draining over an over? or not rinsing at all? if no water coming in check water inlet valve. if its draining over and over>? check ur drainage and water pump
Jun 15, 2015 | Haier Washing Machines
My Kenmore Washing Machine Model 110.82872100 goes through the wash cycle then gets to rinse cycle fills with water makes a clicking noise and stops. Does not drain but cycle knob moves. An electrical...
Your motor is getting overheated in wash cycle. if you turn it off for about 15 minutes and start it back up in rinse cycle will it work ? If yes, then motor is overheated. A sign that the motor is over working its self and time for a new motor.
Dec 15, 2010 | Washing Machines
Loud whirring noise going into rinse cycle. Low
Hi tuck just read your posting.Now on the low whirring noise on the start of the rinse cycle ,Is it when the machine is draining the water or filling with water.If the noise happens when the machine is draining then I think either your pump has something slowing it down or it is faulty.Please look underneath the machine to the front right and you should see a red or black fan .If you do then this is your pump.If you don't see a fan you must have the newer style of pump.Please reply with additional information on the questions and I am sure I can help you rectify this problem
Jul 08, 2010 | Fisher and Paykel GWL11 Top Load Washer
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Water not draining completely after cycle ends
First of all, is your drain hose connected to a kitchen sink or into a standpipe? If its a sink make sure you form a loop or curve in the hose as high as possible above the sinks own waste(plug hole) ,to ensure water cannot travel from sink back into machine. If this is not the case then your water pump, or the rubber pipe coming to the pump has definately got some kind of obstruction inside. Your washing machine has not emptied properly since it filled up at the beginning of the cycle,and has not got rid of the soapy water enough to enable a true rinse.Hence the detergent smell on clothes... Turn off power at plug socket.Take drain hose out of stand-pipe (or connection to sink waste)and drop this hose into a washing up bowl or similar at floor level,to drain off as much water as possible before disconnecting hose to pump or checking the pumps impellar to discover the blockage..Lets know how u get on,good luck.
Sep 01, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Washer does not drain water
You have a sock in the pump. If no noise in spin you have a bad lid switch.
Mar 27, 2007 | Whirlpool LTE5243D Top Load Stacked...
Will not agitate or spin,makes loud noise during those cycles
Sounds like coupling gears between transmission and motor... they did away with the belt and went direct drive with coupling gears. It can pump water out but nothing else. water pump is mounted to front of motor is why it will pump water out.
Jun 19, 2006 | Whirlpool LSN2000LW Washer
Washing Machines Logo
285 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
