Fisher & Paykel GW703 wont stop!
Hi, I have a F&P GW703 washing machine that will go through a complete wash, but at the end of the spin cycle it brakes the spin and immediatly switcthes to Favorite and starts that wash cycle. When the wall power is first switched on (but machine NOT turned on), the 3 spin LEDs light up (orange, orange, red). I have just replaced the main module display unit and the cold water valve inlet. Can anyone help?
  • JD1967 Mar 08, 2008
    Thanks for the idea! (its still doing it 4 months later). Any idea how to reset it?
It sounds like your machine has been programmed to automatically run through the various cycles continuously. Most likely in error.
Posted on Mar 08, 2008
SOURCE:
My Fisher & Paykel washing machine continually stops and beeps on spin cycle GW703. Move clothes around and continue, goes for a while and stops again, seems it is sensing it is unbalanced.
There should be a tech sheet located underneath the control panel that has a fault code matrix. Compare the lights to what you see on the sheet, and read the details.
Mar 05, 2011 | Fisher and Paykel Washing Machines
Model # 110.22064101 Kenmore calypso elite washer makes a whirring sound when washing and the washer tub doesn't always stop correctly when the cycle is complete. It will move around instead of being...
The motor coupling is about to completly go out on you and then it will not spin at all. This is common on these machines. the repair should be under $100.00. The motor brake may also be dragging.
Nov 10, 2010 | Kenmore 24032\24036 Top Load Washer
Maytag Performa agitates, but wont spin corectly.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
Spin cycle error - UNB
Haier have had one or two problems with there spin,
option 1 make sure the machine is balanced perfect [no rocking at all ] use a level on the machine [ truly ] it works.
option 2 you can not wash one item [ underload the machine or overload the machine this will give same result UNB .
option 3 if you have had the machine a few months and this has just started [ clean the armature on the motor with emery cloth and a quick spray of W D 40 please plug out the machine first
0161 355 8254 if you need help , good luck
Feb 17, 2009 | Haier HWD1000
Our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Simpson enduro 701 washing machine
After the water pumps out on each of the cycles the spin does not go or start and it gets stuck there.
Oct 28, 2008 | Washing Machines
Maytag won't agitate during wash
sounds like you have a broken sety fo brake pads, just replaced a set today for same reason, open the lower acess panel and with a flashlight look into the bottom , your lookin for brake pads( theyre probably broken and laying under unit.)
Apr 28, 2008 | Maytag SAV4655A Top Load Washer
After spin cycle washer stops abrubtly causing it to shift.
You have dragging brake shoes. This will cause the motor to draw excessive current. Nedd to take apart and pull down spin tube to access the brake shoes
May 31, 2007 | Whirlpool LSQ9600L Top Load Washer
Washing Machines Logo
404 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
