Question about Acer Altos G700 Server
Restart I have this windows 2003 server running for a year. Starting from the beginning of this year, the machine will restart by itself randomly. It's getting worse and worse. About two weeks ago, sometimes it just shut down. And now it will happen at least once a day. I have tried different memory and motherboard, still fails. Any idea?
  • 432 Answers
Change out the power supply. Dell had this problem with one of there desktop product lines.
Posted on Oct 07, 2007
SOURCE:
Pc restart itself
Do you install any new hardware or Software? if yes boot in the safe mode and remove the software you installed, for hardware switch of the server and remove the hardware component.
Aug 10, 2013 | Computers & Internet
Driver won't work in windows server 2003
Somebody who need windows key click: www.vanskeys.com to got. here i got a working key on my windows about activator. and after i used my windows works properly. hope it help you.
Jul 06, 2012 | HP OfficeJet 6700 Premium e-All-in-One...
Thank you for the last one. know i want to set up mu 3laptops on the windows server 2008 r2 standered and use the server as a domain and the laptops as well like a domain.
first you need to setup the roles in the server, go to the manage server console, ( can be found as a shortcut in the taskbar or under start menu ) then open the console and go to add roles.
1 - add active directory
2 - in the process it will ask you to install the DNS server role ( do it )
3 - after installing the role in the CMD command prompt type DCPROMO
4 - the DC controller installation and setup will beging ( do not do anything during this proccess )
5 - when asked by DC setup to choose what type of domain functionality level do the following
1 - windows 2003 ( this is for compatibility for windows server running 2003 and XP machines )
2 - Windows Server 2008 ( at this point nothing lower than XP can be added to the DC of course domain functionalities will increase - Only other 2008 server domain controller can be added and cluster migration from server 2003 to 2008 is not supported. )
3 - Windows Server 2008 R2 ( at this point only machines running Vista and 7 can be added to domain - windows xp is no longer supported. All the functionalities of the domain controller are available)
keep in mind once you promote the domain controller to a higher level it can't be brouht to a lower level.
once active directory is installed restart you server and the you should be able to add the clients pc or laptos to the DC example
- right click over my computer icon
- click on properties
- computer name
- change the computer from workgroup to domain
- type your FQDN ( fully qualified domain name) example: mynetwork.local or mysite.com
- apply changes and restart
- your computer will be part of the domain next time system boots up.
Mar 01, 2011 | Computers & Internet
Installing seven
install windows 7 ok i like to change boot formate f12 when asked in begining push f2 then change boot format to f12 then f10 exsept then restart computer put windows push f12 run windows under d: drive.
Feb 14, 2011 | IBM x3400 Server
Desktop
restart the computer and at the begining of the restart itself you have to keep on tapping the F8 key and you will get the safe mode option and in that please select last known good configuration and it will work
Dec 25, 2008 | Symantec Norton AntiVirus 2008: Windows
Ntsokrnl.exe is curropted reinstall the file
1. boot with xp or win2003 cd and choose "R" repair in the begining.
choose win installation and write administrator password.
run checkdisk. write "chkdsk /R". enter
2. write "fixmbr c:" enter
and "fixboot c:" enter
restart.
3. if 1 & 2 doesent work boot again in repair mode and try this
write expand d:\i386\ntoskrnl.ex_ c:\windows\system32 overwrite the file.
exit and reboot.
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
User Logoof is very slow...
I have install windows server 2003 install on my machine and it is connected in network through dhcp now it is showing limited or no connectivity
May 07, 2008 | Microsoft Windows Server Standard 2003 for...
Open Questions:
See all Acer Altos G700 Server Questions
Acer Altos G700 Server Logo
113 people viewed this question
Ekse
Alun Cox
