Question about HP Pavilion dv1000 Notebook
To replace two USB 2.0 devices
I need specific instructions in separating the laptop case in order to expose the USB devices I have remove all of the screws on the back of the case. Now, how do I separate the case. The case dosen't separate on its own.
  • 42 Answers
U kant remove the usb fom the mobo, if are dead u must change the mobo :(
Posted on Nov 21, 2007
How to disassemle garmin 4208
If you have the correct soldering equipment and have the replacement part, it shouldn't be too hard. You'll need a jewelers screw driver to get the small screws out. Use a guitar pick to pop open the case. Work it around the case until the back half separates. Clicking and popping sounds are normal. Take out the battery wires. Do NOT yank on the wires... gently grab the plug and wiggle it loose.Remove the screws holding the board to the case to expose the solder side and remove the broken power jack.
Jul 17, 2014 | Garmin GPSMAP 4208 GPS Receiver
How to open case?
To open up laptops you have to do things in a specific order. Not all laptops are in the same order, but usually you need to remove the keyboard (carefully as not to damage the connecting ribbon cable). Once this has been done then you have to remove one (or sometimes more) of the PCB's.
I must say that if you don't have the confidence in doing this then DO NOT CONTINUE and get a qualified technician to carry out the repair.
If you do go ahead make a note of what was removed from where.
Good Luck.
Jun 19, 2012 | HP Pavilion N3370 (F1929A) PC Notebook
Y cant bot cd
There are several things you can do to boot a PC/ laptop please follow the instructions
1. In most pc's and laptops when its booting it will show list of options for example see the below picture now you can see on the top right there are some options given in this case pressing F12 will take you to another menu in which you can select your boot device CD/USB
2. You need to enter BIOS menu of your PC/Laptop and change the boot order
If you don't understand please post your laptops brand and model ia. we can help u
Aug 04, 2011 | Computers & Internet
How do i replace the bios battery in my compaq pp2160
I'm not familiar with this specific computer, but in general, there are two ways, depending on the computer. First, remove the battery and see if there is a little opening from the battery case into the inside of the case. If so, some manufacturers place the battery right in there so you can easily change it. The other computers will need to be opened to expose the motherboard. You'll have to separate the two halves of the case and will most likely see the battery fastened to the palm rest and then plugged into the motherboard.
Mar 12, 2011 | Computers & Internet
My mouse doesnt get detected on my system. please help
Instructions
  1. 1
    Turn off your computer.
  2. 2
    Unplug the power supply, remove your laptop batter, and wait at least 30 minutes before returning the battery and power chord to the laptop. As explained by Trouble Fixers, a cache of data from your USB device is stored on the motherboard. This cache is not completely erased until the motherboard fully discharges following power-down. Once the cache is cleared, most USB errors will be fixed.
  3. 3
    Turn on your laptop computer.
  4. 4
    Try to use the malfunctioning USB port. In most cases, simply turning off and unplugging the laptop will help remedy the problem. If a problem persists, continue with Step 5.
  5. 5
    Click on the "Start Menu."
  6. 6
    Click to open the "Control Panel."
  7. 7
    Click on "System and Maintenance."
  8. 8
    Click on the "Device Manager." A new window will open that lists all hardware and external devices currently installed on your laptop computer.
  9. 9
    Scroll the list until you notice the heading "USB Root Hub." Click on this option.
  10. 10
    Select the USB port that reads "Unknown Device." All other, functioning USB ports should say "unused port" or list a specific external USB device.
  11. 11
    Right-click on the Unknown Device port and then select "Update Driver." According to the tech-help website, Amit Bhawani, this will trigger an automatic update of the USB drivers. If no new drivers are found, the old driver will also refresh and repair. In many cases, a malfunctioning port is simply caused by outdated driver software. With the latest drivers, your port can be used with current USB devices without any problems. If problems do reoccur, then the port may be physically damaged and you'll need to take the laptop computer to a computer repair technician to get a new USB port installed
  12. to forget to leave your comment and testimony
Oct 05, 2010 | Computers & Internet
My usb connector malfunctioning
Instructions
  1. 1
  2. 2
  3. 3
  4. 4
  5. 5
  6. 6
  7. 7
  8. 8
  9. 9
  10. 10
  11. 11
    Right-click on the Unknown Device port and then select "Update Driver." According to the tech-help website, Amit Bhawani, this will trigger an automatic update of the USB drivers. If no new drivers are found, the old driver will also refresh and repair. In many cases, a malfunctioning port is simply caused by outdated driver software. With the latest drivers, your port can be used with current USB devices without any problems. If problems do reoccur, then the port may be physically damaged and you'll need to take the laptop computer to a computer repair technician to get a new USB port installed.
dont forget to leave a comment and state how helpful this post is to you
Oct 05, 2010 | Nokia N70 Cellular Phone
Hi,\r\n When i plug in my Western Hard Disk WD4000ME, its detected by the system and all files are shown, but I cannot copy those files back to the system. It gives the following error:- "The requst could...
An I/O error indicates an issue with the device driver(s) that handle input/output processes such as copying files to/from hard drives, data in resident memory (RAM) waiting to be processed by the CPU or the controller chipset that handles the primary calls to/from the subsystems or a faulty hard drive.
Below are a few solutions that may help resolve the issue and allow you to transfer your files:
Before proceeding, you will need the following:
A. Computer B. External USB Hard Drive C. USB Cable D. RAM Module (Replacement, if necessary) E. Hard Drive (Replacement, if necessary) F. USB Hard Drive Enclosure (Replacement, if necessary) G. USB Cable (Replacement, if necessary)
Note: Solutions B/C apply only to Windows OS.
Solution A. Faulty USB Cable
1. Replace the USB cable. 2. Connect USB hard drive to the computer. 3. Attempt to copy a file from the drive. 4. If successful, copy additional files, as needed. If not successful, skip down to Solution B, step #1.
Solution B. Locked I/O Processes
1. Press and hold the power button on your desktop/laptop for about 10 seconds (or until the system has powered off completely). Then release the power button. 2. Make sure the USB drive is plugged in. 3. Wait another 10 seconds and press the button once again to power on the computer. 4. Once logged in, attempt to copy a single file from the drive 5. If successful, go to step #6. If not successful, skip down to Solution C, step #1. 6. Continue to copy files from the drive. Make sure to pay attention to what files (if any) prompt the I/O error message. If you receive an I/O error, skip down to Solution C, step #1.
Solution C. Motherboard Device Driver Installation/Update
1. Click on the "Start" menu and click on "Control Panel". 2. A new window will open, double-click on "System". 3. A new window will open, click on "Device Manager". 4. A new window will open, listed in the hierarchy are all the hardware components installed on the desktop/laptop. Look for any devices that display either a red "X", yellow "!" or yellow "?". These devices have either incorrect, incomplete or missing drivers/software and need to be installed, as they might be the root cause of the trouble. 5. If any of the above icons are present, perform a Windows Update by visiting the site below:
http://update.microsoft.com
Perform any updates available on the software and hardware side. 6. Restart your computer. 7. Follow Solution C, steps #1-4 to determine if any drivers still need updates. 8a. If updates are not needed, attempt to copy files from the hard drive. If successful, go to step #9. If not successful, skip down to Solution D, step #1. 8b. If updates are needed, you may need to visit the support site for your desktop/laptop's make/model and download any missing drivers. 9. Continue copying files, as needed.
Solution D. Faulty RAM
1. Power off the desktop/laptop and disconnect all cables. 2. Open the desktop/laptop. 3. Remove all the existing RAM. 4. Install the replacement RAM. 5. Power on the desktop/laptop. 6. Connect USB hard drive. 7. Test by copying some files from your hard drive. 8. If successful, close your desktop/laptop and continue copying files, as needed. If not successful, remove replacement RAM and reinstall previous RAM and skip down to Solution E, step #1.
Solution E. USB Hard Drive Case Faulty I/O Board
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install hard drive into replacement USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, skip down to Solution F, step #1.
F. Hard Drive Malfunction
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install replacement hard drive into USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, this could be an indiction of a much larger problem in the form of a Motherboard issue.
If the motherboard is malfunctioning, this is a sign of bigger things to come and will require a replacement board in order to correct.
In the event that the motherboard needs replacement, depending on the make/model of the desktop/laptop, the cost could range from $35-120 for 3rd-party boards or $85-300+ for consumer-level systems from manufacturers such as HP, Dell, etc. and $350-1000 from Apple.
If your desktop/laptop is still covered by the manufacturer's warranty or 3rd-party extended warranty, any hardware component that needs replacement should be covered at little to no out of pocket expense to the end-user. This also includes the external USB hard drive, as well.
Aug 15, 2010 | Western Digital Passport 320GB External...
All three of the USB ports are not working in my Extensa 5620 laptop
First of all unplug everything from the USB ports and the try connecting on device at a time, in order to locate the problematic device. Sometimes one device "blocks" all the ports. In case this don't help, and assuming that you have Windows xp, go to device manager (right click on my computer>properties>hardware>devise manager) and remove (right click>remove) all the devices under the "USB controller" (click on the plus symbol to see all the devices). After that the laptop maybe need to restart. The drivers for the devices you remove will be installed again. After that connect your USB device and it will work.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 11, 2010 | Acer Extensa 5620-4020 Notebook
The fan in my ACER 9410Z is starting to fail. What is the procedure for replacement?
Because this fan is inside the bottom of the computer, you will need to carefully remove the components from the computer and then separate the two halves of the case to expose the motherboard and internals. From there, it is a simple matter to carefully remove the fan and replace with a new one.
Jan 08, 2010 | Acer Aspire 9410 Notebook
I don't have driver of pen drive in windows 98
Let's check your Windows 98 Version first :)
  • Right click on My Computer and select Properties
  • On the System Properties page that opens up click on the General tab, if it is not already on that page.
  • Under the System heading, look for the version number (see right)
    • Version 4.10.1998 is the original version of Windows 98 (98FE)
    • Version 4.10.2222 is Windows 98 Second Edition (98SE)
  • Click the link below for the download and installation instructions for your version of Windows 98
Fo Windows 98 FE:
  1. Download and install the Windows 98 Service Pack (35.5Mb)
  2. Download to your desktop the driver file from the Download section below
  3. Remove ALL drivers for USB flash drives in Device Manager (Optional)
  4. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option) (Optional)
  5. Remove ALL unknown devices from Device Manager
  6. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  7. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
The drivers can be downloaded from the following link:
Windows 98 FE Generic USB Mass Storage Device Drivers v3.20
For Windows 98SE:
  1. Download the exe file to the desktop
  2. Remove ALL drivers for USB flash drives in Device Manager
  3. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option)
  4. Remove ALL unknown devices from Device Manager
  5. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  6. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
Windows 98 SE Generic USB Mass Storage Device Drivers v3.3
For detail explanation, please visit http://www.technical-assistance.co.uk.
It's help for me :)
Thanks
AkulahPathub
Mar 13, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
HP Pavilion dv1000 Notebook Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
