Question about Goodman CLQ36AR49 Air Conditioner
Air conditioner line freezing up
The large line on my air conditoner unit keeps freezing up when I turn my unit on and there is little or no air coming out of vents.
  • Anonymous Mar 17, 2008
    The unit is running outside but the air is not blowing. I looked outside and the pipe has frosted. I turned the fan on and it blows inside and out.
  • 1,420 Answers
Check to make sure the filter inside the air handler is clean and that no vents are closed or blocked by furnature or rugs. Check the air handler to see if the blower is operating. You could have a belt off, the door switch could be in the open position or something simple like that. If this checks out OK., you will need to have a technician check the charge
Posted on Oct 08, 2007
SOURCE:
WHY IS THE AIR CONDITON FREEZING ON THE INSIDE AND OUTSIDE
Usually that means that the unit is low in charge but other things like a plugged filter, bad blower, or orfice, exspansion valve problems can also cause that...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 21, 2010 | Weather King 10AJA4801AH Air Conditioner
Model # m6p09s2a portable maytag air conditoner unit...red light keeps blinking at the unit where power button is located....unit will not turn on. the light just keeps blinking
Greetings,
I have the same model air conditioner, and had the same symptoms. As you've probably discovered, Fedders is the company that actually built it, and went of business. No one is supporting it any more.
However, you may be in luck. I fixed the problem by simply tipping the unit almost all the way over on its back (leave a little gap) and letting the water drain out of the hose and the filter. After that, it started right up.
Hope that works for you. Stay cool. :)
Jun 16, 2010 | Maytag Portable Air Conditioner M6P09S2A
No warm air
could be low on freon and the heating element limit switch could be bad, if it has one
Oct 26, 2009 | Heating & Cooling
Panasonic air conditioner issues
does it freeze up? this could be a sign of low freon. does the fan turn on? if not the compressor will get hot and shut itself down on overload the fan can be easily replaced for around 100.00
Oct 08, 2009 | Panasonic CW-XC243HU Air Conditioner
My air conditioner lines keep freezing up.
You have a blockabe in the distributor tubing which will need a professional to sort out.
Jun 25, 2009 | Heating & Cooling
Do rheem air conditoner hair a reset button
The older unit have a High pressure reset at the outside unit, About center bottom by the copper lines. Push to see if it starts. If it resets you may have a dirty condensor coil. Wash good with water hose. Turn power to outside unit of first.
Jun 06, 2009 | Ruud UAKA037 Air Conditioner
Dometic rooftop air conditioner coil freezeup
We did find a solution, the ducts leading to bedroom in RV was blocked. So far, it has been working since we cleared the way, it no longer freezes up. Thank you.
Nov 24, 2008 | Dometic Rooftop RV Air Conditioner
Compressor lines
If the large line returning to the compressor is frosting you don't have enough air circulation. Check air filters on inside unit.
May 12, 2008 | Coleman Mach 15 Air Conditioner
My AC unit keeps freezing up on the copper lines going into the house from the outside unit. It also freezes up on the inside lines and the air is not cooling my home down.
Operate your air conditioner with the fan in the on position. But first turn the fan on, turn the temp up or shut the cooling off. Your coil is more than likely frozen over. At night when outside temperature drops the refrigerant pressure and temperature in the system also drops. This action can cause icing of the cooling coil, with the fan in automatic everything shuts down at the end of a cooling cycle. Thus no air movement to melt ice on previous cooling cycle.
May 09, 2008 | Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
1,137 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Tom Palicke
Level 1 Expert
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
