Question about Sony KV-32XBR450 32" TV
SONY TV FROM FLORIDA
I received this 32" tv from my parents who live in Florida. I live in Michigan. I hooked it up to my cable (not hdtv cable) and every channel is blury and has a trail. It almost looks like you need to adjust the hue, but we have done all those settings. Nothing makes any difference. The TV is a 2001 model. It is hooked up through my dvd/vhs player. I had a TV guru hook it up for me, which he has done with all our TV's. I guess it's possible it was damaged in the moving van, but first I thought I'd check with you guys. My guru says I dont need HDTV cable for this 2001 model, as the older models would be fine with either. Should I call my cable company? My guru did all the trouble shooting through the process of elimination. We hooked it up with another DVD player, no difference, We used another TV, worked good. We changed all the cable cords, and made no difference. It comes right down to that TV. I hope you have some ideas as to how I can fix this beautiful TV. Thanks, Maryruth
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
We hooked it up with another DVD player, no difference, We used another TV, worked good. We changed all the cable cords, and made no difference. It comes right down to that TV. yes from aboe it is 100% sure that trouble is in tv. every channel is blury and has a trail. it is due to focus of your tv is not ok 1 adjust focus control 2 focur wire going to crt base might be loose due to some foreign material deposited on crt base. 3 defective crt base. 4 if tv is old there might be possibility of crt getting weak. hope this will help.
Posted on Oct 07, 2007
SOURCE:
Black and White Picture??
If you hook up component from cable box you must hook component in put at TV also.
May 09, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
The receiver is hooked up via HDMI and after about
user cable box hdmi direct access to tv hdmi input if ok ...receiver need replaced...if sam proble need replaced cable box...
Mar 21, 2010 | Sony STR-DG1000 7.1 Channels Receiver
I have a 32 in sony trinitron and i do not know
You need a matching transformer, or 'balun'.
Any home electronics store will have these. $3-$5.
Now, if this TV does not have a cable connector on the back, there is a good chance you will not be able to receive many of the channels (not a cable-ready TV).
Jan 11, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No audio output on Philips HDTV Model 32pfl3403
I HAVE A ILIVE SOUND BAR,YOU WILL HAVE TO HOOK IT UP THROUGH A POWER SOURCE WITH YOUR RCA CABLES I ROUTED MIND THROUGH DIRECT TV RECEIVER. WORKS GREAT. HOPE THIS WILL HELP YOU.
Jan 29, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
No play back from HDTV to threater system
Do you have set-top-box or antenna-cable directly to TV?
You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Jan 25, 2009 | Sony STR-DG520 Receiver
NO SOUND ON NEW TV
What kind of Connection do you have coming from the Dish receiver to Your New Sony Bravia TV. This is very important information.
Best regards
CircuitCity
Dec 05, 2007 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony KV-32XBR450 32" TV Logo
96 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
