Question about Acer Aspire 5100-5033 Notebook
Keyboard The @ key and " key are back to front. If I push the shift key, then "2" I get " not @ as displayed.
  • 1 more comment
  • Anonymous Dec 12, 2007
    I have a similar problem.I have a UK keyboard (the @ is on the ' key and the " on the 2 key) but the @ and" have inexplicably changed places-I have tried suggested solution but no luck-any ideas,presumably it's something simple I haven't found yet.
  • Anonymous Dec 13, 2007
    when i press shitt and 2 then its not displaying @ but '. please help me to find where did @ go?thanks.
  • ktyktz May 31, 2008
    When I 'shift' the 2 key for the '@' I don't get anything or I get something totally didfferent. I am new to laptops and wondered if there was a function key or other that i may have hit to make this happen. I have NO instructions and would love some to learn this laptop. Acer 5315-2153.
Thanks that helped alot george
Posted on Nov 01, 2008
Further to my problem I have found the solution-my uk computer has an option for Welsh on the taskbar (CY) this had accidentally been changed to EN, English United States, which caused the @ and " to change places. Clicking on EN brought up the other option, CY. Selecting CY restored the @ and ", problem solved. I don't see why though, all keyboards can't be universal, then these stupid, irritating and unnecessary niggles wouldn't occur!
Posted on Dec 22, 2007
Change your keyboard layout to English united kingdom.
go to control panel > regional and language options > languages > details > default input languages > select english (united kingdom ) - united kingdom
click add > select english (united kingdom) > ok
- wang -
Posted on Dec 03, 2007
  • Anonymous Dec 03, 2007
    change your keyboard layout to English united kingdom.
    click add > select english (united kingdom) > apply
    click english (united states) at installed services > remove > ok
  • 117 Answers
Keyboard short circuit change your keyboard thats a full solve of problem
Posted on Nov 07, 2007
SOURCE:
My shift 2 key does not give me the @ sign and the shift 3 key gives me the number sign. and other errors.
You do not explain what the "other errors" are but the SHIFT 3 is supposed to be the pound sign (#)
Nor do you say what the shift 2 does display if anything.
The most common problem with keyboards is what we in the businees call "Lunch Syndrome"
Basically it's contamination
Hold you keyboard about a foot off the table, turn it so the keys face down , then shake and gently tap the bottom of the keyboard to dislodge the contamination. You may want to lay paper or a towel down as you'll be surprised as what comes out.
Aug 14, 2011 | Dell 0Y3740 Keyboard
Not playing NTSC DVDs
I can see if there is an unlock code for your device
Apr 21, 2008 | Yamaha DVR-S150 DVD Player
Shift key was constantly sticking so everything was typing in caps. I took off the shirt key and there is a little metal bar like a one sided paper clip. Where does that go?
If the bar is what i think it is, it hooks to the keyboard to help push the shift key back up. Easy way to check if that's the purpose of the bar? pop off your caps lock, or the other shift key and see if you have the same bar there. If so, just put it back the same way it is on the other shift key.
On the other hand, if the shift key on the other side of your keyboard doesn't have one of those little bars then with all likely hood the little bar is just a little bar of something that fell into your keyboard. No worries, you can throw it away.
May 04, 2011 | Computers & Internet
When I strike the apostrophe, quotation marks (or double appostrophe)appear. When I Shift + apostrophe, double quotations appear. Same thing happens with the tilde key. So far just these 2 keys...
Sounds like a defective keyboard. I seen issues when pressing a button it will trigger another key to be pushed or nothign displays at all. Try replacing keyboard since they are relatively cheap. othersie maybe a software issue
Mar 03, 2011 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Hello i was writing an email and held down the shift key for to long and an box came up with three options so i just pushed cancelled and now the keyboard is not working properly.capslock is back to front....
It seems your sticky keys got turned on somehow. Press shift key five times and it should turn off the sticky keys feature and fix your problem.
You might be wondering what is this feature all about, so here goes:
StickyKeys is an accessibility feature to aid users who have physical disabilities, but it is also used by others as a means to reduce RSI (or a syndrome called the Emacs Pinky). It essentially serializes keystrokes instead of pressing multiple keys at a time: StickyKeys allows the user to press a modifier key, such as Shift, Ctrl, Alt, or the Windows key, and have it remain active until another key is pressed.
Apr 19, 2010 | Acer Audio Players & Recorders
When I push the shift key and 2 I get the quotations that are in blue
Is that "good" or "bad" ?
Press and hold down the 'ALT GRA' ("alternate graphic") key.
It's to the RIGHT of the "space-bar".
Then, press '2' and then release that ALT GRA key,
and tell us if you see the quote ["] or the at [@] displayed.
Jan 09, 2010 | Compaq Keyboard
Guide
General keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+C (Copy)
  • CTRL+X (Cut)
  • CTRL+V (Paste)
  • CTRL+Z (Undo)
  • DELETE (Delete)
  • SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
  • CTRL while dragging an item (Copy the selected item)
  • CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
  • F2 key (Rename the selected item)
  • CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
  • CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
  • CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
  • CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
  • CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
  • SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
  • CTRL+A (Select all)
  • F3 key (Search for a file or a folder)
  • ALT+ENTER (View the properties for the selected item)
  • ALT+F4 (Close the active item, or quit the active program)
  • ALT+ENTER (Display the properties of the selected object)
  • ALT+SPACEBAR (Open the shortcut menu for the active window)
  • CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
  • ALT+TAB (Switch between the open items)
  • ALT+ESC (Cycle through items in the order that they had been opened)
  • F6 key (Cycle through the screen elements in a window or on the desktop)
  • F4 key (Display the Address bar list in My Computer or Windows Explorer)
  • SHIFT+F10 (Display the shortcut menu for the selected item)
  • ALT+SPACEBAR (Display the System menu for the active window)
  • CTRL+ESC (Display the Start menu)
  • ALT+Underlined letter in a menu name (Display the corresponding menu)
  • Underlined letter in a command name on an open menu (Perform the corresponding command)
  • F10 key (Activate the menu bar in the active program)
  • RIGHT ARROW (Open the next menu to the right, or open a submenu)
  • LEFT ARROW (Open the next menu to the left, or close a submenu)
  • F5 key (Update the active window)
  • BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
  • ESC (Cancel the current task)
  • SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
  • CTRL+SHIFT+ESC (Open Task Manager)
Dialog box keyboard shortcuts loadTOCNode(2, 'moreinformation'); If you press SHIFT+F8 in extended selection list boxes, you enable extended selection mode. In this mode, you can use an arrow key to move a cursor without changing the selection. You can press CTRL+SPACEBAR or SHIFT+SPACEBAR to adjust the selection. To cancel extended selection mode, press SHIFT+F8 again. Extended selection mode cancels itself when you move the focus to another control.
  • CTRL+TAB (Move forward through the tabs)
  • CTRL+SHIFT+TAB (Move backward through the tabs)
  • TAB (Move forward through the options)
  • SHIFT+TAB (Move backward through the options)
  • ALT+Underlined letter (Perform the corresponding command or select the corresponding option)
  • ENTER (Perform the command for the active option or button)
  • SPACEBAR (Select or clear the check box if the active option is a check box)
  • Arrow keys (Select a button if the active option is a group of option buttons)
  • F1 key (Display Help)
  • F4 key (Display the items in the active list)
  • BACKSPACE (Open a folder one level up if a folder is selected in the Save As or Open dialog box)
Microsoft natural keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Windows Logo (Display or hide the Start menu)
  • Windows Logo+BREAK (Display the System Properties dialog box)
  • Windows Logo+D (Display the desktop)
  • Windows Logo+M (Minimize all of the windows)
  • Windows Logo+SHIFT+M (Restore the minimized windows)
  • Windows Logo+E (Open My Computer)
  • Windows Logo+F (Search for a file or a folder)
  • CTRL+Windows Logo+F (Search for computers)
  • Windows Logo+F1 (Display Windows Help)
  • Windows Logo+ L (Lock the keyboard)
  • Windows Logo+R (Open the Run dialog box)
  • Windows Logo+U (Open Utility Manager)
Accessibility keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Right SHIFT for eight seconds (Switch FilterKeys either on or off)
  • Left ALT+left SHIFT+PRINT SCREEN (Switch High Contrast either on or off)
  • Left ALT+left SHIFT+NUM LOCK (Switch the MouseKeys either on or off)
  • SHIFT five times (Switch the StickyKeys either on or off)
  • NUM LOCK for five seconds (Switch the ToggleKeys either on or off)
  • Windows Logo +U (Open Utility Manager)
Windows Explorer keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • END (Display the bottom of the active window)
  • HOME (Display the top of the active window)
  • NUM LOCK+Asterisk sign (*) (Display all of the subfolders that are under the selected folder)
  • NUM LOCK+Plus sign (+) (Display the contents of the selected folder)
  • NUM LOCK+Minus sign (-) (Collapse the selected folder)
  • LEFT ARROW (Collapse the current selection if it is expanded, or select the parent folder)
  • RIGHT ARROW (Display the current selection if it is collapsed, or select the first subfolder)
Shortcut keys for Character Map loadTOCNode(2, 'moreinformation'); After you double-click a character on the grid of characters, you can move through the grid by using the keyboard shortcuts:
  • RIGHT ARROW (Move to the right or to the beginning of the next line)
  • LEFT ARROW (Move to the left or to the end of the previous line)
  • UP ARROW (Move up one row)
  • DOWN ARROW (Move down one row)
  • PAGE UP (Move up one screen at a time)
  • PAGE DOWN (Move down one screen at a time)
  • HOME (Move to the beginning of the line)
  • END (Move to the end of the line)
  • CTRL+HOME (Move to the first character)
  • CTRL+END (Move to the last character)
  • SPACEBAR (Switch between Enlarged and Normal mode when a character is selected)
Microsoft Management Console (MMC) main window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+O (Open a saved console)
  • CTRL+N (Open a new console)
  • CTRL+S (Save the open console)
  • CTRL+M (Add or remove a console item)
  • CTRL+W (Open a new window)
  • F5 key (Update the content of all console windows)
  • ALT+SPACEBAR (Display the MMC window menu)
  • ALT+F4 (Close the console)
  • ALT+A (Display the Action menu)
  • ALT+V (Display the View menu)
  • ALT+F (Display the File menu)
  • ALT+O (Display the Favorites menu)
MMC console window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+P (Print the current page or active pane)
  • ALT+Minus sign (-) (Display the window menu for the active console window)
  • SHIFT+F10 (Display the Action shortcut menu for the selected item)
  • F1 key (Open the Help topic, if any, for the selected item)
  • CTRL+F10 (Maximize the active console window)
  • CTRL+F5 (Restore the active console window)
  • ALT+ENTER (Display the Properties dialog box, if any, for the selected item)
  • CTRL+F4 (Close the active console window. When a console has only one console window, this shortcut closes the console)
Mar 29, 2009 | Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
Keyboard problems
Hmmm...you might have accidently pushed the num lock key or fn key lock. pay attention to what leds are lite near the keyboard.
Otherwise I would see if there was a hotkey driver or keyboard driver from ibm's support website.
Feb 19, 2009 | IBM ThinkPad T40 2373 Notebook
Keyboard Problem
I believe I have a Ghost in My computer, It was delivered defective, And Stoopid Me Iturned it on. Dell has sent new parts, Im happy. But I have a feedback signal thru Telus Internet, replaced Modem 1st mo. new 1 funny 2 not! HOURS on phone, 2 days off work, Im not happy but keyboard works fine now ???????? See. Wierd. Thanx:) DELL inspiron 1525
Jun 24, 2008 | Computers & Internet
Alternate keys on HP Keyboard
Activate:
Ctrl + fn + right shift key
Deactivate:
Ctrl + fn + right shift key twice
so hold ctrl + fn + right shift key then release the right shift key but keep holding the ctrl + fn keys down then push the right shift key again and that should deactivate it
Jun 09, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Acer Aspire 5100-5033 Notebook Logo
187 people viewed this question
Ekse
Alun Cox
