Question about Amana ABB1927DE Bottom Freezer Refrigerator
Freezer works fine...refrigerator section
Works intermittently. It will go okay for a while then makes a buzzing noise while it runs. Then a day or two later the fridge section stops cooling. It will start working again in a few hours or the next day.
  • madisonwidmx Jul 16, 2008
    I think I have a similar problem. The noise I hear is a vibration or humming sound. I took the back panel off the inside of the freezer to get to the fan. When i press on the fan assembly, the buzzing stops. I've tightened all the screws and tried putting rubber spacers between the fan assembly and the freezer walls but the buzzing persists, but it's intermittent. Are these fans multi-speed, or is this a result of condensation/frost build up on the fan itself?Fan on the way out? Fridge out of balance? I'll try anything to stop the hum.
  • 290 Answers
Have you noticed more frost in the freezer than usual? It sounds like you may have moisture building up and freezing around evaporator fan. The fan blade hitting ice will cause the buzzing until it stops it completely or the evaporator clogs with frost and blocks airflow. If you have frost on food in freezer, check the door seals and make sure nothing is keeping doors from closing completely if you release them about 6" from cabinet.
Posted on Oct 07, 2007
  • Michael  Lindley
    Michael Lindley Oct 07, 2007
    If no excessive moisture, it may be the fan motor going out. When fridge isn't cooling properly, open the freezer and see if you hear the fan running.
  • Michael  Lindley
    Michael Lindley Oct 08, 2007
    Just wanted to follow up on your refrigerator problem and see what you found wrong.
    Thanks/Mike
SOURCE:
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
I have a side by side maytag fridge model number MSD2655HES it is about 6 years old. It seems to be cooling fine but makes an intermittent buzzing noise followed by a click what could this be?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 29, 2011 | Maytag MSD2655HES Side by Side...
Hello. I have this fridge-freezer, but unfortunately I can't remember when it was bought. I guess it must be between 7 and 12 years ago! It's worked fine but a couple of days ago it started making...
By your description you may have a compressor problem. The noise is makes if a buzzing noise when it struggle to start (locked up). The clicking noise would be the relay clicking out on overload to the compressor.
If your correct on the date, you will be better off replacing the unit then looking into the repair, a normal compressor change out can run over 500.00. Your best bet is to cut your losses and replace the unit before spending any more money on it.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 28, 2011 | Refrigerators
The refrigerator is making an intermittent buzzing noise. It is a zzzzzzzzz sound, if that helps. It's doing it about every five minutes or so. Model # ABB2527DEW SN# 10128265EP
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 29, 2010 | Amana ABB1927DE Bottom Freezer...
My maytag Wide by Side refrigerator started making this buzzing noise coming from the freezer section every few minutes and now it no longer cools.
It is possible that the door was not closed tighly, so the humidity built up in the duct line and the low temperature from the freezer make it turned into ice causing the clogging. The Buzzing noise turns on due to the sensorsomewhre along the disigne path. Unplug the fridge for a day and a half so the the ice in the duct line could melt down then when you turn on the sensor won't turn on the buzzing any more. Good luck.
Jul 04, 2009 | Maytag Freezers
HISSING SOUND FROM FRIDGE FREEZER
I poked a hole in the freezer with my knife while trying to defrost it. Now it is making a constant hissing sound. what should I do? is this dangerous?
Jan 23, 2009 | LG LRFC25750 Refrigerator French Door
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Bottom freezer works fine....upper refrigerator has stopped working...
Hard to say with this description of the problem but sounds like your having a problem with the compressor starting consistantly. If it is a tecumpseh compressor it is most likely a problem. Take the back off the refrigerator and there will be sticker on the compressor that will tell what kind it is. Should say either embraco(the good kind) or will have a blue picture of an indian head (tecumpseh).
Oct 07, 2007 | Amana ABB1927DE Bottom Freezer...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
341 people viewed this question
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
