Question about EliteGroup ECS 755-A2 Motherboard
New system build won't boot up
! just finished building a New system for my duaghter but the system won't boot up, all I get is a repeating beep.. everthing else start i.e., fans, power supply, dvd - cd & floopy lights flicker, etc. No activaty on the monitor. I checked and rechecked all conections but stiil the same, No bootimg steady beep..! Any help will be apreciated.
  • 3 more comments
  • LatinHeat88 Oct 07, 2007
    I'll give it a try and let you know how it went...Thanks..!
    by the way it's only 1 beep that repeats..!
    thanks
    -Gil
  • LatinHeat88 Oct 08, 2007
    ok I tried your cleaning recomendation and still had the same problem. before trying to do the CMOS reset I desided to change the memory, from 400 to 333. this seems to have solved the problem -in parts- now the system keeps cycling to the safe mood- last good config- etc. screen. but no matter what my selection after post the same screen..
    could it be a defective HD..?
  • rjaduthie Nov 14, 2007
    Elitegroup 755-A2 motherboard
    AMD Sempron 3100+ processor
    1GB of RAM (333MHz, I think...)
    AGP GeForce FX 5200 256Mb graphics
    DVD RW (IDE1 master - tried system with and without this)
    1 Maxtor 60GB IDE HD (IDE0 slave - LINUX)
    1 Maxtor 120GB IDE HD (IDEo master boot - XP)
    Dual boot XP and DEBIAN Etch x86
    The problem started when I tried to plug in a case fan and a HD cooling fan to the system - the next boot up caused the system to sound three short beeps and the power button light to flash on and of at about 60 flashes per second. The HD light is off.
    I can press the power button whilst the PC is in this state and the boot commences. At some point it either freezes or reboots itself automatically - sometimes at drive check, and more often when XP is logging in (just after splash or when asking for the user account).
    Another symptom is when the computer makes a longer beep intemittently with the HD light constantly on, and no activity at all from the system - similar to 'LatinHeat88'. Nothing appears on the screen. The PC needs a hard power-off (holding the power button).
    What is the problem?
  • LatinHeat88 Nov 14, 2007
    Benimur,
    I solved the issue long ago. I formatted a small 20GB HD that I keep around to help trouble shoot. Once I saw that everything was runnig, I figured out the XP was running "Blind" (as you put it) and ran a repair then a reinstall of the OS. Problem solved.! And I didn't lose one bit of information.. I wish I had your solution sooner it would have save me a lot of time, but then again running into trouble and finding your way out -no matter how tideous- can be exactly what one needs from time to time. It helps you learn and share your solutions with others.. Thanks Buddy..!
    -latinHeat88
Okay - A little focus and resolve and the answer seems to be:
To get the system running again...
-unplug all unessential components
[I left my CPU, CPUfan, GPU, GPUfan, memory, both HDs connected inside; keyboard, monitor outside; USB mouse on standby]
-reset CMOS
[a matter of power-down, move jumper, move jumper back after a few moments]
-reboot and enter BIOS, reset date
[if date is not reset then checks may be enforced - DEBIAN Etch will do this!]
-plug in mouse
I have still to find out the cause for the problem in the first place, so as soon as I have all my backups off the drive I will try plugging in the DVD-RW, and each extra fan in turn. I have a suspicion that there is an overload problem (the PSU is rated 500W; I have to ask is this enough?).
Posted on Nov 14, 2007
    Brigadier General:
  • 6,966 Answers
Hi, Depends on the number of beeps and their sequence, the problem can either be video or memory. In some rare instances (Asus motherboards) this would indicate a BIOS problem. Perhaps what you try is to remove the video card/memory, clean the gold contacts using a pencil eraser and re-insert back to the slot. You can also try doing a CMOS reset on the motherboard and thereafter run it a Fail-Safe or Default settings. Hope this be of some help/idea. Post back how things turns up or should you need additional information. Good luck and kind regards.
Posted on Oct 07, 2007
  • Louie  Role
    Louie Role Oct 07, 2007
    Hi again,
    On motherboards with built-in video, the memory is shared.
  • Louie  Role
    Louie Role Oct 08, 2007
    Hi Gil,
    Re your last post "could it be a defective HD..?"
    Either that or that HD came from another system/setup and the OS no longer recognizes the motherboard. On install, XP binds itself to the motherboard config/specs. Transferring HD from one system to another of different model would cause Windows boot looping in any mode.
    You can try re-install using the "Repair" option but perhaps your best route would be to re-install clean/fresh/new the OS.
Rlaptop X551M got new build update of wins 10. it restarted goes to blu screen :( saying unable to start then repeats
Probably windows picked the wrong drivers, if it was microsofts download. Try to get to safe mode and type restore point in the search box. Select a date prior to the update. If it was a windows update there will be a restore point set.
Oct 12, 2016 | ASUS Computers & Internet
D955xbk won't boot
2 beeps is very likely the RAM. Reseat, or test one DIMM, one slot at a time to isolate BAD DIMM.
Oct 23, 2012 | Intel D955XBK I955X Socket 775 ATX...
My dell mini 1012 won't boot up, just beeps 8 times over and over again.
Trying unplugging the computer, remove the battery, open the memory door and remove the memory, clean the memory contacts with a clean dry soft cloth and then replace. Replace the battery, plug in the computer and try again. Sometimes residual power builds up ...
Aug 08, 2011 | Dell Inspiron Mini 1012 Netbook...
Says windows root>\system32\hal.dll. is missing or corrupt, can't use laptop Please advise, regards Jason
some system on your windows has corrupted, it caused by a virus or bad disk
you need to restore your system to fix this issue
if your laptop build in windows xp and you have a restore disk just follow these steps
1. turn on your notebook
2.quickly press ctr and f11 simultaneously
3. click restore when "Dell PC restore" message appears
4.click confirm (it means you will lost all data in drive which contains your old operation system)
5.wait and click finish when the process of restore finish
if your laptop build in windows vista you can follow these steps
1. turn on your laptop
2. quickly press f8
3. when "Advance Boot Menu" message appears just click repair
4. select language and click next
5. log in and click ok
6. click dell factory restore and click next
7. click yes on the box "format hard drive and restore the system"
8. when the process finish click finish
if you don't have a restore disk build in your laptop you need a windows cd installer to reinstall your os
Jun 06, 2011 | Dell Inspiron 6000 Notebook
Dryer appears to 'overheat'...starts a load but stops before finishing then won't start again for hours...
Test air flow. Remove the exhaust hose at the rear of the dryer, run the dryer and form an opinion on the volume of air flow, hook the hose back up, turn on dryer again and verify that the same volume of air exits the building. Usually a build up is the cause of your complaint.
May 13, 2011 | Kenmore Dryers
When boot up i get 1 long and 2 short beep repeatedly. No additional hardware attach to mobo. Please advise
Thats a video card failure.
If the video card is build into the mainboard try attaching a another videocard to the motherboard and see if it boots up
I know the beeping too well, I've had that happen on laptops and well a few desktops, if the new card doesn't solve the problem the mainboard is faulty.
Dec 02, 2010 | ASUS M2A-VM (0610839149438) Motherboard
Quadro fx1800 hangs system on new build
Write to PNY for latest Quadro FX1800 VideoBios.
Jun 05, 2009 | PNY NVIDIA Quadro FX 1400 / 128MB DDR /...
New build computer boot problem
The exact problem is not actually a problem.Just get in to BIOS.
As it is a new system, even if you get to boot from HDD it would say insert proper boot device and press enter or your floppy drive is in first boot.Check you boot settings.
Change the boot order as below.
  • 1st boot device:CD drive
  • 2nd boot device:Hard drive
  • 3rd boot device: anything you want
Now save and exit(F10 then Enter)
Now your PC will reboot.
Drop in the OS CD (Xp , LINUX or whatever)
Install the OS .Now you are ready to use your PC.
Mar 18, 2009 | Intel Computers & Internet
Failed POST
Foxconn uses the Award bios. One beep repeating means, check for improperly seated or missing memory. You can find that here. http://bioscentral.com/beepcodes/awardbeep.htm
Remove your memory & re-seat.
Mike
Mar 21, 2008 | Foxconn 761GXK8MB-RS Motherboard
EliteGroup ECS 755-A2 Motherboard Logo
117 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Matson Kurian
Matson Kurian
Joe Negus
Joe Negus
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
