Question about Concept CM-1100DR 11.2 in. Car Monitor
Car TV I bought this second hand car tv yesterday and I tried to install it myself in my car.I plugged the antenna and the sound is working but the problem is the video. It says in the monitor "video off for your safety". since I bought it 2nd hand it has no manual in it. I tried to press all the buttons once and for a few seconds but to no avail. Please help me I know its an old model maybe you have an idea how to operate the tv. Thank you very much.
  • Anonymous Dec 17, 2007
    i have the same problem and i tried everything but nothin seems to work do you have any other solutions?
    Scholar:
  • 163 Answers
It sounds like not DIY TV repair. Better take it to an authorized service service to check its functionality
Posted on Aug 06, 2008
    Genius:
  • 1,665 Answers
TV must have a cold solder or bad connection in one of the main boards or in the power board . it will be a real pain for the repairman to fix this. in most cases he needs the tv all the way broke before he can find the problem.
  • 26 Answers
The way to go around having to set the parking brake is using a switch. One wire from the unit to the switch, and the other from the switch to ground. that will bypass having to set the E brake.
Posted on May 09, 2008
  • 626 Answers
One of the wires is connected to the parking brake so when it is engaged, you can watch the video screen. Move the wire to something that is constant (+) when the device is moving. Best of Luck.
Posted on Oct 07, 2007
SOURCE:
How do I get PS3 to work on Panasonic TH-50PX70A HD TV?
does the TV work as a stand alone TV with an antenna . if so just use the analog for it and the HD for watching TV
Jul 26, 2015 | Sony Video Game Consoles & Games
Cant tune channels
It sounds like you need to do a complete installation as if TV were new.
This is done from installation menu
Feb 14, 2014 | RCA Televison & Video
I bought a mitsubishi wd 52327 new several years ago. I've replaced the lamp once and it worked fine but now it needs to be replaced again. We bought a lamp off EBay w/housing. I installed it but the tv...
Hi Brent, Mitsubishi's have a problem with the power supply and the Light Engine which incorporates the Digital Module of which it has to be purchased as a complete assembly. I sincerely believe you should not put that kind of money into a dlp set. The cost of the light engine is in the area of $1100.00. Your last idea is the best one.
Mar 09, 2011 | Mitsubishi WD-52327 52" Rear Projection...
I bought an RCA indoor antenna ANT111 yesterday to plug into my Dell w4201c TV. I followed the directions and tried for an hour to find some sort of signal on both the tv and digital tv inputs, but I...
Because the TV is older you might have to change the settings to look for Digital channels. The settings will be on your TV. Let me know if you could find a way to change the setting.
Jan 18, 2011 | Dell W4201C 42 in. Plasma HDTV
I bought a boat with a clarion cd/stereo head unit. I noticed a problem while trying to play the radio that the speakers continually cut out. I get music for 2-3 seconds, then a popping sound, followed by...
try taking antenna lead out of set and put a length of wire into the center hole were the antenna fits then scan,you should pick up at least one station,if you do fit a new antenna,if not try switching off any traffic anouncement services on the set ie press and hold button marked either ta/rds/tta/ast
Topspark
Aug 21, 2009 | iLO XM-MP3-CD Car Stereo
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Crackling noise / loud static when tv is attached to antenna
Pick one:
RFI (Radio Frequency Interference) from nearby electrical/ electronic device.
Antenna misaligned to transmitter.
Antenna coax impedance mismatch.
Faulty connections.
Faulty antenna.
TV tuning.
If the OLD TV worked OK on same antenna it sounds like TV tuning or ANT socket/wiring loose.
Try:
Auto-tune TV with ant plugged in.
Get TVF (TV fundi) or friend to help align antenna.
Maybe a large bird sat on it.
Check coax for sunburn / deterioration. Renew if XX.
Oct 11, 2017 | Televison & Video
Sony play station 1
Im guessing your using and antenna plug.
make sure your TV is on channel 3,4 or Video/Game channel.
If that doesn't work, reply.
Feb 26, 2008 | Video Game Consoles & Games
Concept CM-1100DR 11.2 in. Car Monitor Logo
165 people viewed this question
Top Concept Car Audio & Video Experts
Mike Duncan
Mike Duncan
Robert Rankin
chad zink
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
