Question about Bose 3·2·1 Entertainment System System
Dvd playback During DVD playback, picture is distorted with green and purple color for everything. Also, everything is out of focus - you can make out large items but smaller details are distorted. Sound is fine. TV picture is fine. Have tried multiple discs with same result.
  • 93 Answers
Maybe it's something with picture settings, i.e. NTSC/PAL or INTERLACE/PROGRESSIVE SCAN.
Posted on Oct 08, 2007
6ya staff
SOURCE:
Head alignment
Tracking controls for VHS should have no effect on the DVD player. If a pre-recorded DVD is distorting the picture, along with the VHS, then there's either something wrong with the TV it's played on, or the connection, between the two. Or there is a fault in the electronics of the VHS/DVD combi that deals with the picture.
Dec 29, 2013 | Zenith Televison & Video
HD DVD Audio playback is distorted after microsoft
try uninstalling the audio drivers completely, restart and re-install them
Mar 11, 2010 | HP Pavilion dv9000z Notebook
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
Purple and green color
It sounds like a convergence problem to me. I had the same problem with my set and fixed it myself using a kit I bought from www.TvRepairKits.com. These guys rock!
Aug 19, 2009 | Hitachi 61SWX10B 61" Rear Projection...
DVD playback color is very red
plug red yellow and white cords in all the way
Jan 17, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Color has degraded, not much white, or green
Since yo're getting a good picture from DVD then TV is OK. Replace (reset it first) the box.
Jan 25, 2018 | Panasonic CT-36D30 TV
DVD Freezes during playback
it might be that you are playing a dual layer dvd in the player. The player needs to focus on the second layer of the movie, and that might be why the dvd freezes. Leave it there for a while and the dvd should continue if it is this situation.
Dec 08, 2007 | Sony AVD-C70ES DVD Player
Dvd player in pc
install a powerdvd software on your PC.
A Wndows Media Player and real player can't read a dvd disc.
Nov 17, 2007 | Computers & Internet
Sony DVD player color problem
All These units need servicing, They all are having problems with the video output circuit. It could be a coupling capacitor or the video chip itself heating up and distorting the output after short playing periods.This may be a simple fix of changing the output coupling capacitors. But it also may be some internal distortion in the chip. These unit need to be tested on a oscilloscope and check out in the video out input section to look for possible component failures.You should contact a service center that will test your unit and give you an evaluation of the cost effectiveness of a repair. Hope this helps you with your problems.
Oct 29, 2007 | Polaroid 7" Two-Screen Portable DVD Player
Bose 3·2·1 Entertainment System System Logo
226 people viewed this question
Top Bose Audio Players & Recorders Experts
Ben Armstrong
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
