Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Fsf sdf
    Genius:
  • 1,694 Answers
First = What does sdf mean?.......
Posted on Nov 04, 2007
SOURCE:
What is .sdf file
The .sdf or standard data file is used for storing data in a structured format; uses fields of fixed lengths to store values; can be imported and exported by various database and data analysis programs; commonly used for transferring data between different programs.
Sep 03, 2011 | Oracle 10g Database Standard (ODBSEONUPP0)
Not making a full cup of coffee
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
sdff
sdfs
fsf
sdf
Dec 23, 2010 | Keurig B50 Coffee Maker
How to descale
sdsd
sdf
sfs
fsf
ds
d
Dec 17, 2010 | Keurig Special Edition B60 Coffee Maker
Whst is the difference between .mdf,.ldf & .sdf?
LDF - layered data file, is the transaction log file for your database. It allows you to roll back changes you made to the data to a particular point and is used in rebuilding the data should it become corrupted.
MDF - Meta data file, is your actual data
SDF - Is a sequential data file, a flat file that can be used for compatibility with MS-SQL server, MySQL, etc.
Dec 03, 2009 | Oracle 10g Database Standard (ODBSEONUPP0)
Where can I purchase the orifices to convert my DCS FSF-40 fryers from propane to natural gas? Or is there another way?
Contact your gas utility. They are usually very helful and may even do the conversion.
Nov 16, 2009 | DCS FSF-40 Deep Fryer
What is a .sdf file? How to generate a .sdf file using ms access?
http://filext.com/file-extension/SDF , you will find here info about a .sdf, it has more meanings
Oct 28, 2009 | Oracle 10g Database Standard (ODBSEONUPP0)
Regarding what is .SDF -- A file format that is compliant with the combination of SQL Server 2005 Compact Edition, SQL Server 2005 and Visual Studio 2005 to build, test, deploy, and manage applications for users. Databases of this type can be accessed directly as a datasource, e.g., from Visual Studio 2005, or from SQL Server Management Studio. As such, they can be passed around with programs or projects, although they are mainly used for embedded applications. The file includes all necessary code points to access the data, and so does not require an instance of SQL Server to be installed.
You can create a .SDF file with a software called PocketSYNC. (Although i have never tried it myself, a lot of people claim that this software works like charm. But it is not free)
Oct 17, 2007 | Oracle 10g Database Standard (ODBSEONUPP0)
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
70 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
