Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Smartdrive 708 wont spin or fill it tries but it keeps stopping and starting every few seconds. after a few tries it beeps on and off all the time and 4 lights are lit from right to left red spin. amber next to it next one off next one on green next one off next one on green help thanks
  • baoo Nov 24, 2008
    I have a Fisher and Paykel 7.5 kg Smart Drive 708 (about 9 years old). A week ago it developed a fault that once I select wash, it senses (i.e., rotor moves) and start filling the water. After a minute or so the machine stops, start beeping (and the water temperature setting changes to cold - hot) and control panel selections blink. Then if a reset by pushing the pause button, the machines start again as normal and start filling the water but stops again in minutes or so (same episode as before). I can select rinse or spin and it will do the function normally but it does not complete the whole cycle automatically as it use to do before. (The wash cycle when the rotor spins for several minutes to wash the clothes seems not happening.
    Please advise do I need to resent the control (if yes how) or if I need to do something substantial. If so is it worth getting this machine repaired or should I go for a new one.
    Scholar:
  • 146 Answers
The out of balance micro-switch is faulty/corroded. This switch is located under the motor control module on the right of the machine and is activated by a plastic lever that goes down beside the outer tub. Replace the micro-switch.
Posted on Nov 03, 2007
Testimonial: "Thank you so much Fantastic it works"
SOURCE:
Fisher and Paaykel Smart Drive 708 not working once filled with water.
You need to check your lid switch & out of balance switch for
corrosion and replace if faulty.
Your out of balance switch is under the big yellow motor controller
OOB switch Is where the grey plate is on this picture.
Mar 03, 2013 | Fisher and Paykel Washing Machines
Washing machine doesnt work kelvinator smartdrive 085 0.5kg
you have to check 1- water pressure switch (wps) , 2- the hose which fixed between wps and drum may disconnected or broken.
Jun 12, 2017 | Kelvinator Washing Machines
My Fisher and Paykel Smartdrive 7.5 kg fwon't agitate
when they beep the main p.c.b bord has detected an error on the f/p series the main fault we have found with this is the small icb sensor that runs along side the capstan drive drum try cleaning it if this does not work try replacing the head control p.c.b bord
good luck
Jul 06, 2010 | Washing Machines
No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
May 30, 2010 | Fisher and Paykel Washing Machines
F & P Smartdrive 708 has all lights showing when powering on, but will not start wash cycle. Have tried turning off at wall to re-set; taken lid off but still no go
take the motor shroud with the magnets in it off you will probably find corrosion on the terminals on the small circuit board clean it off, whilst you are at it check your pump is spinning freely if not pull it off and dismantle it clean the rotor it may have a rust buildup on it, when putting it back together give the bearing holder a few taps to centre the shaft before you tighten the screws completely, if it tightens up when you tighten the screws give it another couple of taps either side of the bearings until it frees up
Oct 30, 2009 | Fisher and Paykel Fisher & Paykel Washer
The machine stops at wash cycle every minute or so
Firstly, the model 708 is way more than 9 years old. More like 18 - 19 years old. There is 2 types of errors on a smartdrive. One is signalled by a single beep every second & the top row of lights will change. The 2nd is a rippling musical sound (like when you turn the power on at the wall) and some lights will be blinking. You need to tell us what sound it is and which lights are blinking or which of the top row lights are on (exactly, count from the right to left and which number is on & which is off) There is no such thing as a reset to do. Once I know the fault I can advise you what to do about it.
Mar 10, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
1,189 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
