Both sides running but not cooling. shut down remover back cover from inside freezer section and found coils iced up. freezer is a auto defrost.
shutdown and thawed freezer and restarted, seems to be fine been 2 days so far. will this happen again. does anyone know why this happens. it happened a few months ago and I did the same thing then.
maybe the doors where left open or my wife moved the settingd up more than 1 setting.
Rick
What is ADC
Have you seen this before and are you a repair person.
thanks,
Rick
Thanks,
Will a partially opened door contibute to the problem? About a half inch open overnight.
I was on the fridge side that was open for a while.
I thawed it out aweek ago then noticed something on top of fridge keeping the door from closing all the way. then the same problem came back with coils frozen up, thanks..
One thing i am now noticing is that the frige does shutdown after running for a few hours.
Maytag SBS Refrig, unit runs, fan runs, but freezer only gets down to 20 and the frig only gets down to 60. Manually de-iced the coils about 2 months ago when I had the same problem. I suspect the coils are iced up again. I don't think it is an air infiltration problem because both doors seal well and we pay particular attention to this detail after the 1st time is happened. I now suspect the heater may be bad or the circuitry associated with it. Any ideas?
What else could be wrong?
What parts are connected to the heater?
Are these easily replacable without major surgery?
coils in side by side keeps freezing up and refrig get warm. defrost and refrig works for ony 2 weeks
does not cool
Adaptive Defrost Control
It is possible ADC is bad
