SOURCE: I have a 2hp black and decker circular saw. Went
If the motor is 3 phase (which it may be if it is 2 HP) , it will run backwards if 2 of the wires are traded position. You may have changed the wires in the plug if you replaced a plug.
SOURCE: I need an Owners Instruction Manual for a Black
you might want to try Dewaltservicenet.com with the exact model number of this tool for that manual
SOURCE: I can't tighten the blade on the saw.
are both flanges in place and on correctly?? That would be the first thing that I would look for.
SOURCE: My black and decker, circular saw, blade moves
Some things like this we have to improvise. Possibly a filler washer can be used. It is not clear if the shaft end play is what you have, or the blade clamping washers allow the movement. If it is the blade clamping, possibly there is a burr on the washer that prevents the proper mating of the clamping washers.
If it is shaft end play, then try to use a fiber type washer to fill the gap.
SOURCE: How can I change the circular saw in my Back &
Unplug it and loosen the bolt in the middle of the blade. It's a standard thread, so turn it lefty-loosey. But you need to hold the blade from turning. That's easy by putting a screwdriver in front of a blade tooth, under the sole plate. Let the sole plate prevent the screwdriver from rising up with the blade as you turn the bolt. If your current blade has small teeth (like a plywood blade) then you can raise the sole plate as for a maximum depth of cut, then push the saw against the front edge of a workbench (or block of wood somehow held still) as if you were going to cut it. Before you remove the bolt, take note of the exact orientation of the washer (or washers)so you can replace them the same way.
Testimonial: "Thank you very much; more or less what husband had tried to do, but none the less he's going to try again, according to your instructions. Will let you know the result later. J"
