Question about Lite On K17AN (Beige) 17 in. Flat Panel LCD Monitor
Strange PINK colors
When i switch on my LCD all that is supposed to be white is pink. And it looks like everything is slightly blurred. I bought the LCD as is (from a friend), and was wondering what could be the problem. Is there any way to fix it and whats it gonna cost? NEED AN URGENT REPLY, BECAUSE STILL HAVE TO PAY THE GUY. SO I NEED TO KNOW IF ITS WORTH FIXING...
  • 56 Answers
The pink tinting is common with a failing back light or back light transformer. Usually easy to fix If you know what you are doing. price depends on size of the monitor and where you buy the parts.
Posted on May 22, 2008
    Problem Solver:
  • 6 Answers
This problem from display cable or may be dry soldering
Posted on Oct 07, 2007
SOURCE:
SCREEN IS PINK AND NO SOUND..MENU SCREEN COMES UP IN CORRECT COLORS
How to Fix TV Pink Screen, Tech Tips 16 - YouTube
? 0:51
https://www.youtube.com/watch?v=84tyJ6A1frg
Apr 13, 2013 - Uploaded by Tampatec
Turning on and off the TV (not cable box) does recharge thescreen and the colors will properly disperse ...
Why is everything that was white now colored pink on my ...
www.makeuseof.com/.../why-is-everything-that-was-white-now-colored-...
Dec 15, 2015 | Televison & Video
My kodak easyshare cx7430 camera has pink in my pictures, how do I get that out?
follow this steps and fix it. God bless youVersion:1.0 StartHTML:0000000168 EndHTML:0000003236 StartFragment:0000000502 EndFragment:0000003219
1. The batteries may need replacement. Somedigital cameras continue to function when their battery power is low, but produce grainy photos with incorrect coloration. Make sure you aren't using Ni-Cd rechargeable batteries, which are generally not recommended for cameras.
2. For the best picture quality, make sure the camera is set to its highest resolution. This may have been adjusted by accident. The process for doing this varies greatly among different digital cameras. Keep in mind that fewer photos will fit in the camera's memory and it will probably take longer to transfer them to the computer, at a higher resolution.
3. Digital
photography tends to be more prone to blurring (caused by slight movement of the camera while the photo is taken) than 35mm film, especially with very small or lightweight digital cameras. To remedy this, try using a tripod and/or the camera's timer, if it has one. Adjust the camera's shutter speed if possible.
4. If colors are too pale, using an image editing/viewing program (such as PictureWorks MediaCenter) to increase the Saturation level may be helpful. If the camera has produced colors which are entirely wrong (everything is in shades of black and purple, for example), you can turn the saturation all the way down so that it becomes a black & white photo.
5. The lens may need cleaning. Make sure you use a cleaning material which will not scratch the lens. If possible, refer to its manual for specific cleaning instructions
Jan 30, 2013 | Kodak EasyShare CX7430 Digital Camera
Everything that is supposed to be black is showing
Hi,It sounds like a problem with the color wheel or DMD board. The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will hear ,humming,buzzing,high pitch noises ,you might also experiment color distortion ,black and white picture. This is how the DMD works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 29, 2010 | Televison & Video
I have a compaq desktop, winxp sp3. white has turned pink
The monitor needs some minor repair and alignment that's all
If you are any good with electronics and have a bit of decent test gear lying around you could probably do this job yourself.
But if not then a local TV or computer repair shop will be able to handle it and it should not cost too much.
Its a common problem on older CRT type screens
Aug 19, 2009 | Computers & Internet
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
Pink Screen
The reason its pink has two possibilities one is that you have a bad cable and needs to be replaced the second and most likely is that the backlight bulb is going out on you and will need to be replaced. When backlights go out things look pinkish reddish and then just go out all together.
If this helps please rate fixya
Thanks
May 04, 2009 | ViewSonic VA1930WM LCD Monitor
Overall pink cast and pink stipe at top of all images taken.
Never had that camera, however, had the same problem -- the pink stripe and pink cast. Turns out the lens cover was slightly cracked and not opening and closing properly. Thus -- the pink cast.
Mar 26, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Toshiba laptop screen goes wierd
This was probelm of lcd panel
u go nearest service center and check lcd panel
Jul 14, 2008 | Toshiba Satellite A75-S229 Notebook
Pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Jun 02, 2008 | Televison & Video
Open Questions:
See all Lite On K17AN (Beige) 17 in. Flat Panel LCD Questions
Lite On K17AN (Beige) 17 in. Flat Panel LCD Monitor Logo
140 people viewed this question
Top Lite On Computers & Internet Experts
Pierre Laplante
Ekse
Damen Wong
Damen Wong
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
