Question about Averatec 3200 Notebook
Plug in is broke
My plug in to charge my pc is broke need help how to fix it
  • 3 more comments
  • tesla4all Nov 03, 2007
    need to disassemble ...all done except still holding string at read. I need to fix the power jack. Any help on this one?
  • knowr Dec 07, 2007
    I have no power to LT
    I think it could be power jack.
    I have removed the power jack assemble and was wondering if anyone knowws where to get a new one
  • Anonymous Jan 08, 2008
    renewing ip address
  • Anonymous Jan 17, 2008
    Who do I contact to get the problem fixed? I can not take it apart myself.
    K
  • Anonymous Oct 23, 2008
    yey my lt wont turn on either i even boght a new charger but still no green light
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
A helpful hint for anybody that has to repair the power pin is after you repair the pin make sure you use a CRD (Cable Retention Device) to keep from causing the problem again. I use and recommend the JerkStopper. Even some Mac (MagSafe) Users are using it these days. We have three in use in our household (2 Fujitsu laptops and 1 Mac).
Posted on Apr 25, 2008
    Problem Solver:
  • 14 Answers
AVERATEC IS FIXING THE POWER SUPPLY PLUG UNDER WARRANTY REGARDLESS OF THE AGE OF THE LAPTOP. MINE WAS 4 YEARS OLD AND I SENT TO TEXAS AND IT WAS REPAIRED AT NO CHARGE. THE PART WAS DEFECTIVE IN MANY UNITS. CAUSING THE MACHINE TO OVERHEAT OR NOT CHARGE. IF U CANT FIND THE NUMBER TO CALL SEND ME AN EMAIL.. [email protected]
PS I NEED A COPY OF THE INSTALL DISKS THAT CAME WITH THE 3200 AVERATEC
Posted on Jan 29, 2008
They sell those ac adapter jacks that you can solder right on the motherboard,, about $6
Posted on Jan 09, 2008
Hi I am a new guy here and someone helped me out. Now it's my turn. 2 years ago my Averatec 3200 power jack broke. I ebay searched an Averatec 3200 power board replacement. This replaces the little board the jack is mounted on and includes a very solid external screw down connector for about $50.00. It's the best power jack solution out there except for Apple's magnetic connector. This is the latest link. good luck.
http://cgi.ebay.com/Averatec-Power-Board-for-3200-3300-Series_W0QQitemZ280147669364QQihZ018QQcategoryZ114206QQcmdZViewItem
Posted on Dec 04, 2007
Of course you can fix it.  The power jack on my Averatec 3200 laptop shattered as well.  You just need a new jack that fits the power supply connector, some thick stranded wire, and some basic soldering skills.
Unfortunately I was unable to find exactly the same jack they used, so I couldn't solder it straight into the motherboard like the old one.  It was also a pain to disassemble the laptop, keep all of your screws in a dish!
Once you get your laptop disassmbled:
  1. Take *careful* note of where each terminal (the inside pin and outside conductor of the jack) are soldered in on the motherboard first.  They're probably still soldered in, but the plastic case is broken.
  2. Desolder the pieces of the old jack and solder some stranded 12 AWG wire it's place.  Use wire that's between 2 - 4 inches long.
  3. Using black and red wire, solder the black wire to the location on the board where the outside conductor of the jack connected.  Solder the red wire to the location where the center pin conductor was connected.  Bring the wires out through the power jack hole and screw your laptop back together.
  4. Using a replacement jack that mates snug with your external power supply connector, solder the red wire to the inside pin conductor and the black wire to the outer conductor of your new jack.  Use some heat shrink sleeving or electrical tape to cover any exposed copper.
Be very careful to get the +/- polarity right with your wires, I don't know if they have polarity protection built in to the motherboard.  If they don't you could do some serious damage if the polarity is backwards.
This will look ghetto, but my laptop has run great for over a year since that fix (until it recently started overheating).  If you can manage to find the exact same power jack that they used, bringing wires out to a different shaped jack won't be necessary.
I'll be taking my laptop apart again soon, so if you need some pics let me know.
Good luck.
Posted on Oct 18, 2007
    Sergeant:
  • 457 Answers
You cant buy a new one..........
Posted on Oct 08, 2007
SOURCE:
Why won't my ipad wont turn on or charge
When you plug the cord into the iPad do you get a charging icon?
Jun 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Samsung laptop battery charger tip stuck inside how do I fix it
you have to replace your charging connector on the your laptops mainboard...... or take it to any hardware speacialist
Feb 15, 2014 | HP Computers & Internet
Can not charge
The socket that the charger plugs into has come loose from the control board. The only thing you can do is open it and resolder or send it in for repairs.
Jan 20, 2014 | Trust Flex Design Tablet
My toshiba satellite L25-S1194 wont turn on. no lights, nothing. how could i fix this?
Try taking the battery out, plug the computer in, and see if it turns on. Press the "Power" button for at least 20 seconds (and press hard). If that doesn't work, put the battery back in, and do the same thing. I assume no lights appear like its charging (as you said). If this is the case, then you might have a dead charger (wire broke inside, power surge broke the adapter, etc). You may want to try a different charger of the same model (either from your local Best Buy or from a friend). If it does look like its charging, then your laptop's power supply has died (or the motherboard has died). This is a much bigger hardware problem and should be under warranty (or time to buy a new laptop). All data should be recoverable, however.
Jun 19, 2013 | Toshiba Satellite Computers & Internet
Ac adapter broke
Buy a RIM Blackberry Rapid Charger. It uses another connection:the one with the three magnetic contacts.
It was about $10 on amazon today. And it charges fast.
Feb 24, 2013 | RIM Blackberry Ac Adapter 5 V Dc 1.80 A...
My battery does not charge, because the plug in for the rear of the laptop seems to be broken. Can i cut the cord and redo it to another plud in.
If the plug in the laptop is broke the only options you have are to have it fixed or to buy a universal docking station. The docking station will use your plug and will charge you laptop
May 15, 2011 | Toshiba Computers & Internet
Ds will not turn on
Okay, So according to your problem, you could try maybe to remove all possible outside connections ( DS cardtridge or GTA Cart) Then try actually changing the battery itself as maybe it is the battery problem, but thats all i can help to. : ) Hope you get them fixed soon. You could get them looked at at a NDS shop too
Aug 31, 2009 | Nintendo DS Lite Console
Acer aspire 5570-2758
You need to contact Acer before your warranty runs out. Tell them your problem and they will advise you on how to proceed. Here is the Acer support website, start by choosing your location: http://global.acer.com/support/service.htm
Jan 08, 2008 | Computers & Internet
Averatec 3200 Notebook Logo
307 people viewed this question
Top Averatec Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
