Question about Frigidaire Affinity ATF7000ES Front Load Washer
Frigidaire affinity I just bought a brand new washer, got it home and it will not work. It fills with water, but the tub will not turn, the timer works. I have done all the obvious, the plugs are out, the door is closed, etc... It is Saturday now, I was wanting to get it going before Monday when I will be able to schedule a trained tech to come come out and look at it. Thanks in advance
  • thelm76 Oct 07, 2007
    I fixed it, I took it back to the store and got another one. I Think the original had some pretty good problems.
  • 209 Answers
If you tamper or work on a new machine the guarantee will be void keep off, an experienced engineer can tell if anyone has had the lid or any panels off have patience wait for the engineer sorry ps I am a recently retired appliance engineer of 20 years and i can tell
Posted on Oct 07, 2007
6ya staff
SOURCE:
My Frigidaire Affinity washer has black mold on the rubber seal .how do I remove it ?
set washer to hot water wash fill detergent cup with bleach put rest in tub run entire cycle i would rewash to make sure all bleach is out
Jul 09, 2014 | Frigidaire Washing Machines
WHAT does E11 meens washer does not take in water
Good Afternoon Friend,
I understand that your Frigidaire Affinity washer, model# ATF705BZHS, is not filling with water and showing an E11 error code. The E11 code means that your washer is taking a long time to fill. First, make sure that the incoming water faucets are turned on. Next, you will want to make sure that the pressure is above 30 PSI. I suggest resetting your washer, by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire AFFINITY WASHER ATF705BZHS FOR...
Why does my frigidaire affinity smell
clean it by using 5 cups bleach fill soap cup put rest in tub wash in hot water long cycle run another or 2 after to make sure bleach is gone
Jun 07, 2014 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire affinity front load washer ATF6000FS1 wont fill with water
Hello hitman43 - Are the house valves turn on fully? Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Contact a professional to move forward accurately.
Jan 01, 2013 | Frigidaire Affinity ATF6000F Front Load...
Problem with water in tub of front load washer
Two possibilities here - bad valve, not closing completely when off or you have a bad control that is sending residual voltage to the valve when it is off. Contact a service technician.
Aug 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Cold water won't stop filling the tub
The cold water valve is probably stuck open. It should open only when there is voltage across the valve. It could just be clogged inside. If you can remove it, you might be be able to take it apart and clean it. Just make a note of how parts fit together as you are taking it apart. Clean all parts with old toothbrush and reassamble. Before you reinstall, connect it to a garden hose outside. No water should come out when you turn the hose on. If it still fails, just buy a new valve.
Jan 24, 2008 | Frigidaire ATF6000ES Front Load Washer
Affinity front load washer
my front load washer won't spin water out
Jan 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
