Question about Bosch BSG81360UC Premium Health Guard Bagged Canister Vacuum
Bosch BSG81360UC Vacuum Motor Won't Run
The green power light is on, the beater bar head will run, but the suction motor will not start. This machine appears to have no motor reset that we can see...
2 Suggested Answers
  • 6 Answers
SOURCE: Bosch vacuum Motor turns off after a few minutes
It sounds like you have a motor protection fuse that resets after an overheat/cooling cycle.These work the same as a circuit breaker in your house with the difference being they can reset themselves.The Bosch will also shut down if there is insufficient airflow and I would check your filters first.1) Pull the filter and let the machine run.Do not pick up debris when you operate without a filter-it will be drawn straight into the motor.If it runs fine without shutting down, all you need to do is change your filter.If it shuts down again check the external hose for any blockages.Also check the throat from the powerhead for any blockages.If you continue to have the same problem then you will need to replace the fuse because at this point you have eliminated all the other likely problems.Good Luck-Scott
Posted on Oct 08, 2008
SOURCE: No motor action when the power is ON
I have the same problem with mine -- precisely the same model BSG 81335UC. It feels like the power button switch isn't working properly.
Posted on May 14, 2010
0 characters
1 Points
The beater bar in my vacuum does not go around and there is no suction in the power head?
Turn up side down- check if belt is intact- I would remove belt ant look for an obstruction. Not familiar with this vac but some motors have replaceable bruches on the motor. Try running and feeling for suction. The motor should sound strong when running. Remove beater brush and check for freedom of movement.
Jul 28, 2014 | Sebo Felix Classic Bagged Upright Vacuum
The suction comes on but the motor doesnt turn the beater bar nor does the red or green light come on
check to make sure power is coming from wall with a voltage meter, if not wiring issue or blown motor or wiring around beater motor
Feb 28, 2014 | Lindhaus Vacuums
Beater bar motor quit, now the main motor quit. Replaced the on/off switch. still nothing
see this causes and fix it. God bless you
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Vacuums
Power only comes on when vacuum is not upright
Power or beater bar? Beater bar is supposed to turn off when upright, but suction motor should still run.
Nov 14, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
It has no suction...
Assuming that the vacuum will run, remove the bag and check the discharge to the bag from the machine for debris. Also check the suction to the vacuum blower by removing the beater bar cover plate and beater bar. Inspect the belt. While the bar is off, inspect the suction hose behind the beater bar. This is where I usually find the debris.
Regards, --WoobieDog--
Jul 10, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Green light quit working
The small magnet on the beater bar had fallen off. I repositioned it & now the light works.
Jun 24, 2009 | Kirby Heritage II Vacuum
Brush does not turn on my vaccum
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Jan 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Dec 31, 2008 | Bosch BSG81360UC Premium Health Guard...
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
While vacuuming the beater stopped.
ok what u have 2 do is replace the belt. real easy so i will tell u how,first unplug the vacuum cause you need your hands for the next step. now turn it over and the part where the roller sits your going to have some screws prolly 2 take them out the cover should come off youll see the roller the pulley and the broken belt if your lucky find the belt size replace it put back together and you should be back in business....
Nov 26, 2007 | Bosch BSG81360UC Premium Health Guard...
Bosch BSG81360UC Premium Health Guard Bagged Canister Vacuum Logo
Top Bosch Vacuums Experts
Ryan S
Ryan S
Pieter Vleeshouwers
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
