Question about Olympus FL-50 TTL Flash
Flashing auto check and test/charge
Please help! I work normal with this flash, but for no reason the flash won't work. Battery's are fully charged, but after a view minutes the two leds are flashing. nothing works, only the power button. In my Olympus E 510 a red flash symbol appears, and it won't go away. i have tried to reset, but without success. Please, what is wrong? Greetings from Holland
  • Raynaq Feb 23, 2008
    I'm having the same problems, and have replaced with new batteries 3 times, and the lights still flash. Help!
  • mosastre Sep 08, 2013
    the solution below showed that the batteries are low, how do we recharge them on the flash
This means that your batteries are low on power.
Posted on Oct 07, 2007
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
Two new alternators on and the car still will not charge and it kills alternator. Need to know what to look for in the wiring harness. Auto Zone tested alternators before installation. Still won't...
Go to web site WWW.HMASERVICE.COM and register your vehicle by VIN #. You'll then have access to shop manuals, wiring diagrams, technical service bulletins, illustrations, etc.
Provided there is no problem with the vehicle's wiring, find out what the charging current is to the battery. I've seen batteries which TEST good, but when under a CHARGE short out internally.
Example: Tested a battery & charging system on a Hyundai Elantra, the battery tested "Healthy" but indicated there was a CHARGING SYSTEM PROBLEM. I checked the battery voltage while the engine was running and found the battery voltage at 14.3 VDC (which was normal). I then used a Digital DC Clamp meter arount the positive (+) battery cable & found the battery was charging at 70 Amps!.. it was supposidly already fully charged (should have only been taking 4 to 6 amps when fully charged).
Best guess without looking/diagnosing the vehicle myself
Maybe this will help.
Jun 30, 2011 | Hyundai Elantra Cars & Trucks
Orange battery light is doing a double blink right now... Does that mean the battery is being charged??
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
or you may try If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective - please look for a replacement. Hope it helps.
Jun 25, 2010 | Sony VAIO PCG-K35 Notebook
My invacare auriga 3 wheel scooter will not work got 2 new batteries but will not power light flashing on charger as if charging but when put key in not even lights comne on
hi,
Can you clarifly what happens you plug in the charger in ?
Are you sure the fuses on the battery leads are okay ? the is one for each battery like a glass container ? check they have not blown, check the connections to the battery , are they tight ?
Regards
gewizrepairs.co.uk
Nov 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Battery is fully charged but it still wont power up no lights when plugged in to charge
Hook up only the ac adapter to the DS to see if it turns on. If it does then we know the ac adapter works. We know the battery got fully charged but the system isn't turning on with the battery that is fully charged up.
I would say your battery is defective but you won't really know until you fully charge up a known good working battery and test it out.
Jun 29, 2009 | Nintendo DS Lite Console
CASIO EXILIM EX-Z70 BATTERY CHARGER IS FLASHING RED AND NOT CHARGING THE BATTERY
it wud flash red until it gets fully loaded..its normal...try charging for 90 mintutes..as that is when it is completely charged
Happy to help
HAve a nice day!
tc
May 11, 2008 | Casio EXILIM ZOOM EX-Z70 Digital Camera
M670 notebook not charging when plugged in
Charge the Battery fully before first use . The red flashing indicator shows that the battery has been deeply or fully discharged . Please Connect your laptop to AC power source and let it remain for well over 10 hours atleast.If the battery pack is alive it might recover and start working normally.
Apr 27, 2008 | MSI Megabook M670-046US Notebook
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Olympus FL-50 TTL Flash Logo
331 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
